i dun think u would of damaged the diff from jacking it up there.
I jack from their whenever im doing work on the rear end.
Besdies i think thats where you meant to jack it.. as i cant recall anywhere else u can...
Unless you got a hoist.
https://www.sau.com.au/forums/topic/212527-mods-pls-delete/#findComment-3754998
seems to be more noticeable after jacking it up
or do gtr diffs just sound like this :worship:
Oh BTW Orion, get a Rear Wheel Alignment done.
Cuz you have change the rear suspension, its put the geometry out of whack and needs to be done cuz its 4WD.
But I don't think that will help with the whirring noise. Or it might...
But when you jacked it up at the diff, I don't think you would have crushed or bent anything in the diff...
Anyway get ya mechanic to check it out.
My diff made a similar noise when rolling and while driving. Sounded like a Wwhhoooo noise. So I got it reconditioned.
https://www.sau.com.au/forums/topic/212527-mods-pls-delete/#findComment-3756471
I still got the receipt for my rear diff
About $1380, thats recondition, installed ready to drive and it was not as much as I thought too.
But get it check out 1st.
I did it at Le Mans Automotive in Templestowe.
https://www.sau.com.au/forums/topic/212527-mods-pls-delete/#findComment-3757776
You would of snapped a cooling fin before doing internal damage to the diff..
Not form the jacking.
Sure your not just Paranoid?.. Happens to me too..
Whirring diffs seem to be common threads in this section.
Just seems like their noisy from factory.
Best advise is change the diff oil.. see the condition its in and put a higher quality product in. See how that goes..
People jump to recondition diffs/'boxes too quicky.
For that price you may aswell buy an after market LSD.
https://www.sau.com.au/forums/topic/212527-mods-pls-delete/#findComment-3761475
ill have to get them to check the diff oil then on my next service
but i just had a major major service and replaced all fluids, and if anything the diff whirr is louder!
what diff oil did u use???
https://www.sau.com.au/forums/topic/212527-mods-pls-delete/#findComment-3763886
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
