So you mean you've reved out to 9000rpm and never hit the limiter?
I never knew GT-Ts can rev to that high, Man.. yous must be quick!
i never thought so myself considering the stock dash starts redline at 7000rpm untill i realised my car just freely revs almost off the clock ands sounds like it could go further, ive raced other cars and by the time theyve hit 5th gear im still in 3rd reving it out and still taking the lead so it is an advantage
FWIW
Revving an rb25 to 9krpm is not a good idea... It will screw your head (bend a valve due to valve float) and wear out your rings... The engine just isn't designed to rev that hard.
Also, if you still have the stock turbo the car would be faster if you actually changed gear at the redline because the power curve will peak at about 6000rpm and well and truly tapering off at 7krpm let alone 9krpm.
FWIW
thats why ive only occasionally briought it out to 9000rpm i havnt hit it in a while coz i didnt want to risk blowing anything but its good to know how high the rev range hits, i did have plans to put bigger turbo upgrade n work the motor a bit, i guess the next owner can deside weather to do that or not
just found out previos owner had apexi rsm on the car and brought it out to 11 100rpm the cars nuts thanks to the vvti the car loves high revs neva had any problems car runs beutiful always maintenaced even at high revs sounds healthy so i duno
I think what aphid means is that its stock INTERNALLY and has only bolt on mods, as you have listed:
Performance:
- Turbo back exhaust with blitz nur cannon
- HKS front mount intercooler
- Aftermarket Top Secret ECU
- Boost controller
- Automatic turbo timer
- Pod filter
- HKS oil cooler
- Heavy duty racing clutch
- Lightweight flywheel
- HKS hyper-d Coilover suspension
- Aluminium air deflector
None of these mods will help the car to rev to 9-11,000 RPM safely.... So if you do actually rev it that hard, which is doubtful, it could/would be causing serious damage to the engine. And on a stock turbo it would be making F All power reving that high as its wayy out of its effiency zone.
I dont mean to be negative, because its a very very nice looking car, you just dont need to say things like that to try and impress guys on here...they know these cars too well...
Anyway, Good Luck with your sale :P
thnx mate i just thought it was pretty unique for the car to be hitting such high revs and wanted people to know what it was capable of and still running healthy if the car doesnt sell im just gonna keep it so i can still be in with the skyline family :)
yeah sorry if i sounded harsh, but mate, limit that beast back to 7000rpm.. it's a beautiful looking car, but 9000rpm is really really stupid, anyhow.. back on topic. free bump :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
