Hey guys, just wondering what the concensus with GTR owners was regarding suspension setup.
My 32 has Apexi adjustables at the moment which is good, but I find it slightly hard and it tends to skip over harsh small bumps. Seems good at moderate speeds and smooth roads and has no bodyroll...
I don't know if is simply not setup right or if Apex should just stick with electronics. How much will a decent set of tyres affect my setup also?
Interested to hear from you GTR owners on your experiences as everyone I speak too has a different opinion ie Tein coilovers, Bilsteins etc...
https://www.sau.com.au/forums/topic/212793-suspension-advice-gtr/
Hey martin, I have the Tein HA coilovers on my GTR and they are rock hard too on 265 x 35 x 18.
I drove the car back from Sydney and felt every stone I went over and even on the softest setting (16 steps) its still pretty hard.
They would be great for circuit though.
Hey Martin, What profile tyre are you running as that will definetly make a differende 35 series compared to 45 series etc. Forget if you said Saturday night if they were damper adjustable or not? If so did you try winding all the way soft see if it makes a difference? The aftermarket swaybars would also be tightning up the car and helping to cause the skipping aswell. Check spring rates also. needless to say iam running the ISC in my GTR and have no issues but it all comes down to personall preference and what you use the car for.
Ryan
hey pete, yeah I am using same 265x35x18s.... not real sticky ones tho.
They simply did not have enough grip around mallala. Good fun all the same!! But I dont know where the shocks are set... will have a play with the stiff/soft settings and see how it goes... however most people I talk with say that the Teins work real well on the GTRs.
Ryan
hey Ryan, yeah I am using 35 profile tyres, and my intended usage is track days and street but the car is not a daily so it can lean a little more towards track....
What sort of price would a set of ISCs to suit?
I am considering getting some 17s with some semi slicks for the track.
Edited by HOSTILE
Changing the rebound won't do much about the harsh ride.
The rebound adjuster is how fast the shock rebounds after it compresses. Too slow and the shock will keep going up and down and not settle fast enough.
Your problem and the problem with almost every coilover out there is that the spring rates are far too high. The japanese do this to mask their inability to valve shocks correctly.
Your better off with a kit from the group buy over any all in one wonder coilover.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
