Hey guys i have a R33 GTST and i installed a Z tune style bonnet on there and today it was pissing down with rain and i think that some water has go into the spark plug hole because its sounding like a WRX and just keeps misfiring? so im just wondering if i take off the spark plug cover and clean up all the water will the car run back to normal? would anything happen to the spark plugs?
Cheers
Chi
https://www.sau.com.au/forums/topic/212851-water-in-spark-plug-area/
water wont get in the spark plug hole unless youre spark plug wasn't in properly... it could have got down and shattered the ceramic on the spark plug... but i doubt it... could be a a spark plug has gone (through use) or even could have got water in the air intake... is your filter inclosed? and is there a vent near it??
Yep its the vented bonnet "I got rained on and my coil pack cover isn't water tight" sound...
The hard part is getting the water out, I used a long piece of clear hose and gravity to drain the water...
Afterwards make sure the rubber seal on the coil pack cover is on straight and sealing properly, I leave the back of the coil pack cover loose to let heat out so my splitfires don't get overheated.
The water will evaporate but its not advisable to do it that way...
hmmm well its not in the hole im just saying it could be sitting like aroudn the spark plug? mmm perhaps some CRC and alot of rags to drain the water :glare: mmm it doens't have a vent for the air filter part but yeah ill see tomorow perhaps its time to invest in a new filter :D
Cheers
Chi
what new filter, the water is nowhere near your air intake? An I missing something?
its sitting around your spark plugs and making them arc...
The ztune style bonnet has vents directly above the coil pack cover, thus why making sure your coil pack cover seals are installed correctly will resolve the issue for the future...
as long as the coil pack cover is sealed there is no problem... I too have a vented bonnet and had the same problem at first since I didn't run a coil pack cover at all... sealed it and all is good...
Tighten the screws I believe is what he means.. Otherwise silicone would work but surface would have to be cleaned extremely well (if you wanted more protection) Alternatively find some silicone boost hose split it up one side and slide it down the sides of the cover and glue together at each end and screw down should do i decent job if you get it in right
Cheers
Chi
where did you get the bonnet im looking for one at the moment!
I hear they are really bad for getting water down in there and it will wreck your motor....i will give you $200 for it :(
hahah ur wishing :ermm: hmmm just go tanother question....i have cleaned all the water out of the spark plug area boosts fine until 5k it starts misfiring perhaps if i replace the spark plugs it will be all good??
Cheers
Chi
Cheers
Chi
Where did you get the bonnet?
Probably worth taking it all out for a day to let it dry out i think you can bugger your coil packs getting them wet just like most electrical things they can get wet but its the corrosion that will kill them in the end!
My GTR has a vented bonnet also, When it rains it scares the hell out of me.
I have no gargage so i put a car cover over my car, I am sort of lucky the water hit's the fan so it's really not going on the top of my engine lucky because i have no engine covers.
water can get in the electrical plugs( cas connector) and cause the same problem. but sounds like u need new plugs or coil packs.. most ppl dont run the coil pack cover to stop them getting as hot.. but then if u dont, u get the problem with water.. but thats easily fixed compared to the price of a coil pack
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
