Is it wrong to drive through a puddle on the side of the road with the intention of causing a wave to soak unsuspecting pedestrians who are just going about their business, or waiting for a bus etc?
I know its a wan*er thing to do, and everytime the oportunity presents itself, i do try to refrain from doing it....but its soooo funny that i sometimes cant help myself. If you saw this happen, would you swear and curse the person, or would you be more inclined to laugh?
For the record, i think some people should be off limits. e.g. Kids, parents with kids etc.
So, am i a really just a wan*er??
Be honest, do you do it, or have you done it?
Have you ever been hit by a wave while you were a pedestrian?
https://www.sau.com.au/forums/topic/212906-pedestrian-puddles/
  • Replies 81
I got hit by one as a kid on my skateboard, and after I had got over the initial shock/anger, I realised how piss funny it was and have never managed to pass up an opportunity since.
Mind you, being the wanker kinda makes you assume everyone else is gonna do it so you learn to stay right away from roadside puddles.
haha i have been victim to the bus driver. but that was for the bus i was getting on, so i couldnt really avoid standing there
if you are a pedestrian and are stood on the edge of the kurb where you can see a puddle that has the potential to splash you then its your own fault for standign there
so its perfectly fine for a driver to drive through a puddle, its on the road you cant really avoid it now can you? eheheh
Hey i have been behind busses that have done it a lady was holding an umbrella and tried to use it as a shield didn't work very well, i have seen some people that are so addicted to doing this they take their own water with them to splash people
bit harsh perhaps. i would be reluctant to tsunami ladyfolk, or people wearing suits, imagine if it was you lol.
that said, my dream tsunami moment would be a mass of teenyboppers waiting outside a nightclub. paint their blinding fluoro clothing with good old fashioned mud!
baaahahaha awesome thread....... back in my hay day (yr11-yr12) we used to go around in my mates hilux surf jacked up with monster bf goodrich all terrain T/A's in winter before school looking for the opertunity...... the tables have turned considering i havnt been driving for the last 12 months... winters just coming up and we've had a few rains.... i keep an eye out and stay a way from those good old puddles when walkin just to make sure..... i recon it would be pretty uncomfortable covered with road water and grime lol
Setting up the car with big tyres etc, then driving around looking for the opportunity...thats just being a right prick about it!
p.s. love your work though :D
haha yesterday mourni it was rainin and traffic had come to a stop in wangara near the bmx track so i decided as i was in the patrol too go thhrough the dirt, as i was going through thee ruts flat out they wer full off water and i accidently covered about 5-7cars in mud, felt bad but was kinda funny, then i got scared id get bogged and they catch me
man i fkn hate when 4wds do shit like this! maybe its because i am secretly envious of them having more than 70mm of clearance lol.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
