Item:
Tein HA Coilovers - set of 4 to suit R33 GTST. Height and 25 point damper adjustable.
Item Condition:
Excellent condition, just removed from car due to selling. I also have the C-spanners and a set of solid Pineapples to go with them as they are no use to me! No leaks, a very nice set of suspension.
Contact Details:
Contact on my mobile: 0404 80 1900 or PM. Note that I dont get on here as often as I used to so the preferred method of contact is my phone.
Price and price conditions:
$750 negotiable + postage. SOLD
Item:
R33 3 inch stainless steel mandrel bent exhaust.
Item Condition:
Excellent condition, just took it off my car. It is a straight swap for a standard exhaust and bolts up to the stock cat. There are a few scratches on the bottom - as to be expected.
Contact Details:
Again: Contact on my mobile: 0404 80 1900 or PM. Note that I dont get on here as often as I used to so the preferred method of contact is my phone.
$400 $350 + postage.
Thanks guys, any questions ask!
Edited by harvesteros
Hi mate, I think about 20 000, I have done less than 5000. This is going on the kms told to me from the previous owner. I got them checked out before I bought them at a suspension shop anyway, your more than welcome to do so again.
How many KMS on the suspension??
A hell of alot harder.
Thanks mate. Yep they are fairly stiff but not too bad on the softest setting. If you do wind the damper up to full it is rather insane and you do tend to get stuck see-sawing on one front and one back wheel when going into driveways etc. Bit of a hoot.
would the exhast fit a r34 gtt or just r33?
Not really sure on that one but I would not take the risk, im sure they would be different. Maybe someone else knows??
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
