last year there were only 5 or 6 ACT members and about 35 NSW... How would it work if its the same this year?
Im going for the "Fastest R32 Gtst" title again this year... But I think that Reece will be in his R32 this time and not the Starlet so there could be some stiff competition. :)
But ACT still did very well with only those few...
We go up against Vic's vs NSW with only a handful of people and we do well..
Fastest R32 ay...Good Luck!
Fire Extinguisher is definately a good thing to have anyway
  • Replies 89
I spose youre right we had a couple in the top ten last year (myself included)... Im keen as mustard this year :(
Im going for fastest R32 Gtst, not fastest R32 (although that would be nice). >_<
got another question, since a racing licence is required as well as a helmet, does that mean a fire extinguisher is needed as well?
The organisers will need to confirm, but my understanding is that as this isn't a "speed" event i.e. chicanes will be strategically placed to bring the pace down, that a fire extinguisher is probably not required for this particular event. Although a L2S is good value because you can use it elsewhere/other events i.e. Hillclimbs and AutoSports track days at Wakie, I think you can run with just the L2 at this even.
I reiterate though, confirm with the organisers.
Bugger, I would really like some good ACT based competition out there this year... Everyone knows that I was 2.5 seconds quicker than Michele and 4 seconds quicker than Reece last year :D
5 times the horsepower, Coilover suspension, Decent tyres, Decent brake Bias
4 Seconds behind in a car worth less than your turbo.......PRICELESS!!!!!!!!!!!!!!!!!!!
Fastest Outright, I'm aiming HIGH
Going for slowest GTR, As lag will play a big factor in the tight turns... :(
RWD Mode, + Clutch kick = 0% lag
But seriously just pick the right gear and you will be fine, unless they spool at like 4000+ then its a bit iffy
^lol, 4.5 to 5 i get good boost... :) on hard at 5.5 :O
Oh, ok :D
I bet you, you could have no turbo and flog the starlet with power,
So if you don't beat the starlet, you can't blame LAG for your lap times
Edited by TURISMO
Oh, ok :laugh:
No i will blame you for driving to fast...
Edited by BNR32t
ACT, List.
5. Keith Hickling (BNR32t) - Received Payment
9. Reece McIntosh (Turismo) - Received Payment
14. Michele Guyer (Michele)
15. Mark Guyer (Tuk Tuk)
16. Brendan Donnan (Donnan) - Received Payment
18. Chris Jirgens (CeJay) - Received Payment
If i missed someone please add yourself.
Edited by BNR32t
So you think doing the back track in rwd would be better?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
