Hey guys,
To start, I have an R34 GT-t,
I've noticed that after a long weekend of cruising and such that suddenly the car seems to shudder slightly when driving, this occurs from the moment i start driving so it irrelevant to whether the car is warm or cold.
After some reading/research i've come to the conclusion that it is the coilpacks, the car has done around 83,000 kms and as far as i know the coil packs have not been changed thus far.
And i believe that generally speaking, the stock coil packs usually give out around 60-70,000kms, further strengthening my belief that they are the problem.
Now i have 2 questions regarding this:
1. Is it safe to still drive the car for a week or so until i get together the money for some new coil packs.
2. Are they difficult to install, ie: can i do it myself, or is it best to leave it to a pro?
any feedback would be appreciated,
Thanks
Steve
https://www.sau.com.au/forums/topic/213057-coil-pack-issues/
It will be fine to drive the car.. as far as u are aware they havent shutdown yet.. just dont put the car under excessive stress..
Installing them is a little bit time consuming,have to have to take off / take appart a few things, best bet is to find a "how to" guide on doing the spark plugs. will tell u exactly what to do.
May as well change the plugs while u are there too.
Platinum plugs are spose to be good for around 100,000kms i am lead to believe,
best bet is to have a look at them when u are doing the work and if u think they need replacing then go ahead and do it.
I only have copper plugs in my car but im going to be changing them every 10-20,000 kms.
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
