Item: As title States
Age: its a 1997 model
Condition: side damaged
Price: OFFER ME!! willing to post at buyers expense
To Fit: (What car) where ever you like
Contact: Nam pm, 0421175987 if i dont answer please leave an sms
Comments: i brought this engine off ebay, i thought i was able to use the engine for my car but the water pump area was too damage to fix. so i decided to strip the engine; i will give a full list once my mechanic has strip the full engine, or if your keen send me a pm of the part you want!!
i will post more pictures up later tonight! and the prices!!
I JUST WANT TO GET RID OF IT!!! PLEASE COME DOWN inspections welcome, im only available on thursday friday, saturdays mornings to 230pm
TAKE THE WHOLE REMAINING OF THE MOTOR FOR $400!!!! NO TURBO ITS SOLD!!!
cheers
Nam
post-37040-1207197662_thumb.jpg post-37040-1207206642_thumb.jpg post-37040-1207206676_thumb.jpg
post-37040-1207197689_thumb.jpg post-37040-1207206713_thumb.jpg post-37040-1207206755_thumb.jpgpost-37040-1207206790_thumb.jpg <----- its because of that water pump area crack and the crank that i couldnt use the engine
post-37040-1207206828_thumb.jpg post-37040-1207206864_thumb.jpgpost-37040-1207206898_thumb.jpg post-37040-1207206934_thumb.jpg post-37040-1207206975_thumb.jpgpost-37040-1207207043_thumb.jpg
Standard R33 cams
$20 inclu postage
Standard Injectors for r33 or to fit any other
$120 including postage
Standard r33 afm?
$40 inclu postage
trust pod filter
$10 just come pick it up
Standard throttle intake upper
$100 including postage
Standard R33 ecu manual 1997 rb25det
Standard behind cam cover plate?
$30 incl postage
Standard Fuel rail and everything that in the picture apart of it
$140 including post
CRANK - $100 PICK UP / RB25DET HEAD $250 PICK UP
RB25DET PISTONS - $50 PICK UP
Edited by nszs
Hey, I need the coolant bleed assembly, it's bolted to the plenum. Do you still have it? Thanks
hey, im a bit of noob when it comes to engine!! so help me out ?! i dunno what that is!? :P
hey is the engine wiring loom OK?and is it a manual ECU?
by the looks of the loom its doesnt look that its in really good shape i post the pic tomorrow for you to see, and yes it is a manaul ecu
It is in the circled area in the attached pic, it has 3 small hoses coming off it. One to the throttle body, one to the head & one to the block. It also has a 10mm headed bolt screwed in to it.
Hey mate.. will you sell the turbo seperately?
If so, what condition is it in? Shaft play? etc.. If its all good, consider it sold! :P
Cheers!
Edited by _x_FiReStOrM_x_
i call dibs on the coil pack loom so long the clips are not broken pm me back with a price + delivered to Adelaide 5013.
cheers
Allan.M
i check it out tomorrow for you,
If so, what condition is it in? Shaft play? etc.. If its all good, consider it sold! :)
Cheers!
hey the turbo has no shaft play, come down and inspect it, and if you like it; its a $150
cheers
cheers
Allan.M
do you have the coil pack loom thanks
hey mate is this what you looking for?
is that the square thing that connects all the coils together?
yeah the plugs that connect to the coil packs is the loom plug clips broken at all and is your motor a series 2?
just pm me back please
cheers
Allan.M
Edited by R334door(s2)
hey does anyone know if the series 1 and 2 Coil Pack Loom are the same i know series 1 have the ignitor on the coil pack cover and series 2 have them built in the coil packs is the loom its self the same thoe.?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
