I got my 34 GTR two months back and know exactly how you feel. Driven many a different car over the years from Porsche to XR6 Turbos but have never driven anything that compares to the 34 GTR. Mine is absolute stock, but the Stage 1 mods are coming next week as I just cannot resist the feeling of starting to experience the full potential of this superb machine. I keep on telling myself that it will end there, but suspect the heart will overule the brain once the exterior trinkets are tweeked, and the internal surgery beckons!
Many people consider that I am in the midst of a mid-life crisis, but to me, I am beyond that, and have reached the Pearly Gates!
Best of luck with your R.
makes it all the more sweeter when you have worked hard for many years but desired the car for so long but for reasons were unable...Finally you got your reward...CONGRATULATIONS !!! Hopefully in another couple of months ( If my house ever sells ) I will experience the same feeling...Beautiful machine
Welcome to the GTR club.
I have had my R33 GTR now for 2 1/2 years and the feeling is the same every single time that you drive her.
There is nothing else that I have driven that has the same level of grip that these things generate. The only challenge is to treat her with respect while you are getting to know her as you experiment with her limits.
All I can say is enjoy..........
