Im gonna ask a big favour here...
Would any1 with a 34gtt or series 2 r33 with rb25DET neo engines be willing to let me borrow their coil packs to see if it is my coil packs that are causing me dramas?
can do it at your place or mine... alcoholic reward perhaps?
Thanks in advance
Steve
Edited by RusH_
https://www.sau.com.au/forums/topic/213415-r34-and-r33-series-2-owners/
i have gtt
since i lost my job and have nothing better to do than surfing will be hapy to help u out,
since im new to skylines will be happy to ask few q.
cheers
drop pm if interested
P.S. i hope it want do anything wroong with my engine
Great that your helping him out Steve...But don't worry, you can't hurt your coilpacks by doing a transfer. If you lived near me (sunshine coast) I would be happy to do the work for free on the weekend.. installed probably 4 or 5 sets now on 33's and 34's, turbo's and non turbo's.
So let me know if you need any advice/help as I am more than happy to assist.
have a great day.
Chris
i have gtt
cheers
Thank you very much, ill post up shortly and/or pm you if i still need to do a check
have a great day.
Chris
Cheers chris, if i have any questions ill be sure to hit u up, and yeh i dont live very near the sunshine coast, way south as a matter of fact lol.
hey mate i have a full set of R34 GT-T coil packs let me know if u need them your welcome to try them out
Ah sweet thanks Vish, once i get a diagnostic done ill let you know if i still need them :laugh:
Edited by RusH_
Mate, it's your coil packs...if it's throwing up the error code and running like shit don't go through the pain of changing them over to find it is them (which you already knew), then having to replace them with splitfires as well.
Just get the splitfires and be happy :laugh:
What error code might that be Dan?
i had the probs your having the stock coil packs start to break im unsure of error codes but ur free to try them out whenever you want bud .. i wouldnt waste too much money finding the faults get a multi meter and test the coils yourself save some $$ in the end too
Pm me whenever you want em bud :P more then happy to help out
would u believe im eatin kfc as i read this topic? lol
thanks vish, see u then,
also thanks for that document dan, only without sounding too dumb, its a tad confusing, at any rate ill test out these coil packs and see if it solves my issue
It may read a bit intense but basically, turn the car to On (don't start)...short out the two consult pins for 1 sec (check engine light will go out)...count the flashes of the check engine light....that's it.
You only need a 10$ multimeter to test the condition of your coilpacks
Bah-barp, wrong! You can't tell with R34 ones just by using a multimeter, they pretty much fail under operating temp, and the have an isolated firing circuit inside which will not tell you anything by measuring resistance.
Almost all R34's have the packs shit themselves, just replace them and avoid the agony and time looking into a problem that is well know and can't be fixed by silicone, tape, araldite or gypsy tears!
can anyone tell me where to get spitfire coil packs from, i have a problem with ine, and cant be f**ked waiting 2 weeks plus from nengun
www.perfectrun.com.au were quick with my ones
I may even suggest Slide, make sure as hell he has them in stock down the GC though or it could be a Nengun + billion year wait
Can refer you to a supplier in brissy... he should have it in his garage.. Pm me for details if keen..
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
