i shoulda explained, i have a rb25 with a rb26 harnes, and i am using 740cc rb25 injectors lol thats why, i would trade them for rb26 inj, but if there is no resistor box wont circuit be open
Don't you also have the GTR plenum?
For the cost of high CC side feed injectors it would be cheaper to get a custom fuel rail and the cheaper top feeds.
EDIT!! i have just seen that you already have the side feeds.
The RD25DET injectors are High Impedance
& The GTR injectors are Low Impedance
But i think you already knew this
Edited by D_stirls
i got a custom plenum, the resistor box if what changes the low impedence to high impedence some peopel said just dont run the resistor box but i think that will leave the circuit open
anything, i dont wanna have to buy a new fuel rail, and sell my injectors and get rb26 inejctors and a resistor box ( hard to find)
To bypass the resistor box, you simply connect all the pins together, so the injectors get 13.8v. Pretty sure plugs are different too. What are you planning on doing about the VCT?
msd rpm activated switch i got pics
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
