Make: R32 GTST
Model:93
Milage:160,000
Transmission:RB25DET 5 speed
Colour:black
Complied?Yes
RWC supplied?Supplied on sale
Currently registered?March 09
Price:$22,000
Contact: PM or mobile 0404002142
Comments / Modifications: See below
Images: See below
ENGINE
Built RB30DET (less than 10,000km)
Weisco forged pistons, shot-peened stock rods
ARP rod bolts and head studs
Fully balanced rotating assembly
Rebuilt stock RB25DET head.
RB25DET Gearbox
High mount stainless steel exhaust manifold
GT35R with .86 Ex Housing
Tial wastegate
Plumb back BOV
Greddy Intake Plenum
Q45 Throttle body
Walbro fuel pump
555cc Nismo injectors
NPC button clutch
Haltech E11v2
Has made 373rwhp on 20psi.
SUSPENSION
SAU Group Buy Suspension kit (less than 5000km):
Bilstein Shocks
Whiteline springs
Whiteline Camber and caster kits
Whiteline front and rear sway bars
OTHER
JVC touch screen head unit
12in subwoofer
18in wheels
TurboSmart EBC
FMIC
3in Exhaust
Momo Steering wheel
Dual Thermo Fans
Central locking
Alarm
More photos to come this weekend including interior. The car only gets driven on the weekend and I have home renovations that require funds. I would love to keep it but it is alot of money to have just sitting in the garage.
Edited by BH_SLO32
https://www.sau.com.au/forums/topic/213949-black-r32-gtst-93-model/
nice car mate. would of thought you would have made it well in to the 400hp mark with the gt35 and 3 litre bottom end on 20psi
Yes, I am sure with a bit more timing that is quite possible. My tuner likes be conservative with his tunes. The car previously had a stock 25 in it with the same turbo setup. Only 3 degrees of additional timing was added over the RB25 timing and the 3L runs about 8.2:1 compression. The head also has stock camshafts.
wot boost is the car tuned to and wot power is it making? cheers
Tuned to 20psi and made 373rwhp. The motor was bought last year from a guy who had it in his VL commodore. The owner said no expense was spared on the engine build and he had it tuned for 24psi with a T66. The dyno graph showed 640rwhp. So I am confident the motor has more potential in it. Ultimately I achieved what I wanted from the setup so had no reason to lean on the motor.
Cheers
Edited by BH_SLO32
hmmm no expense spared on the motor.... stock rods pushing 640hp thats a bit of a worry. hows that fuel pump handle? herd the walbro's only have enough puff for about 240-250kw? wot did ur tuner say about the pump? who tuned your car? and do you have receipts for the rebuild? sorry bout all the question, I am interesed though, cheers
Yes, the owner supposedly spared no expense on the motor although he still used the stock head and cam shafts - go figure. I saw the 640hp power figure on a dyno chart but am not willing to comment on its authenticity or accuracy. In my experience there are many factors which govern the recorded performance of a car on a dyno hence the variations in power between different dynos. Needless to say a cars performance down the quarter mile gives a good indication of its potential. With the old RB25 motor and GT35R running 16psi (293rwhp) the car managed a terminal speed of 110.5mph (low 12s) despite the problems launching the car with the old suspension.
I did get some receipts from the owner of the engine but they only cover the machining work and engine assembly and show purchase of the ARP gear. The owner was quite willing to pull the head off to show the forged pistons although I didn't see this as a necessity given my ultimate goal of not more than 300rwkw. I was also told the block was O-ringed.
Walbro is great. I have provided it with a direct power feed thanks the battery now living in the boot. I expected the fuel pump to limit the power the engine made and would expect it to be close to its limit.
My cousin, Phil Laird, tuned the car. He is a well respected tuner in Australia.
The Electronic boost controller has 3 settings. Normal day to day driving I run on setting 1 which is 13-14psi.
Hope this sufficiently answers your queries.
Cheers
Edited by BH_SLO32
ben, so sorry to hear th car is going ;) it sad to see this go, i can speak on ben's behalf, i never saw the car run but it looks amazing in person gl with the sale, who ever buys it will definatly get enjoyment and a bargan out of it! cheers, Hame
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
