If you run the appropriate fuel all the time, then there may(should) be power to be gained by advancing. However if it pings(for one of many reasons, which you may not hear), then the ecu will go into its low octane map, richening the mixtures and retarding the timing. There is no engine light, and it will stay in this mode until the ecu is reset i believe, there is "power loss and worse fuel economy" especially if you then retard the timing to the original cas position, then you have even more retarded timing and richer mixtures.
Edited by Adriano
ok have been having a few problems, my c.a.s has problems with the tps switch unpluged if i set the timming say 15 degreees btdc then turn the car off and back on still with tps unpluged it will say timing is around 30degrees btdc and rev alot higher its wierd its as if the car flicking inbetween modes when i turn it on and off but will only do this with t.p.s unpluged and yes i did reset ecu before checking the timing because i had played with it does anyone no what happening
at to you guys, if you have a series 2 motor (might be applicable to series 1 aswell) you must use a short ignition lead from the coil pack to the spark plug. put the timing light sensor around that and then you'll get and accurate reading...
bump anyone have any idea...
bump i have also found when i tightn the bolts up on the c.a.s timing wil drop by 5 degrees example i set c.a.s to 15 degrees btdc then tightn the botlts up being sure not to knock the c.a.s and the timing will be down to 10 degrees btdc is this normal
Edited by rich flavour
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
