hows it goin, currently have a sr s13 with just ova 300rwhp and considering selling this and buying my grandad's datsun 260z 2+2 seater...
260z
like below(not the actual car lol)
plans would be
rb25det with a target of 250rwkw
hks gtrs
FMIC
Alloy Radiator
EBC
Bosch FP
FPR
555cc injectors
Power fc (or equivelent due to rarity)
Z32
Foward Facing Plenum
ORC Twin Plate
3" Turbo back, probably with varex for stealth n performance
LSD
upgrade suspension - sway bars, springs n shocks or something
disc brakes all round
Interior as it comes...
Exterior
MSA type 3 front bar(Pic of below)
prob black paint job
some nice rims
---QUESTIONS---
Any1 know if i could source rb gearbox and engine mounts for 260z in perth? or in aus?
being a 1970's car, 74 i think... would i have 2 run a catalytic converter? lol
any specialist shops of the z car in perth? searched but couldnt find much
will be doing probably everything except tuning at home... with help from the old man wanna pretty much do everything from making piping to custom mounts to full rewire (auto sparky apprentice) to painting to like everything haha neways want this to be built by me not just driven by me :)
also would like to hear from any whos done this conversion... already got a heap of info from other websites but can never have enuf
Thanx Guys
Jason [PS13WA]
https://www.sau.com.au/forums/topic/214050-considering-260z-rb-transplant/
Hey mate.. Used to have 240z. You will love the car dude with an RB in it. Adelaide Z cars are doing RB conversion for customers Race 240z at the moment, and Vic Z club has a few members with RB's in their old school Zeds. As long as the 260Z was built pre emissions then you can get away with blue murder, but to be honest I would still run a cat. It will be less hassle when you get pulled over if you dont have to "explain". Another good conversion is SR20 in 240/260 as the motor sits further back giving slightly better balance. Get on a Zed forum quick mate.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
