Think I gotta have a look at the Stag tonight.
I'm aware the BOV outlet is plumbed back into the inlet system after the AFM, but somewhere along this path I've got a leak. I can hear it, although all the piping/rubbers are in place.
Might get the GF tonite to rev it and get it boosting so I can find the leak.
4 Qs tho:
Anyone had this problem before?
Obviously its not harming the engine?
Is there a better method for checking the leak?
How do I get the GF to clean my car while she's at it? :D
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/
  • Replies 49
Posted Images
i am sorry to say that i can answer only no to all of the questions above :D its not good to hear that you have a leak somewhere.....i guess trace all the vacumm hoses and stuff to see what is going on where.....
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3781628
dont bother with your car running cause you may find a leak if your lucky but you may not.
grab a frezzer bag from the pantry, undo the hose clamp where your intake goes onto your AFM.
remove the afm and put the bag over the end of it and then reinstall as normal.
now remove the vacum line to your FPR or similar and stick compressed air in there. this will pressurise the whole intake system and alow you to pin point any leaks from the intake manifold right up to the afm.
leave the bag double thickness will hold about 1.5 bar.
evryone should do this now and then as you will find even the smallest of leaks.
cheers
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3781832
you havent just whacked on a POD by any chance have you?
you may have a leak in your cooler pipes, usually around the hose clamp join bits...?
Yeah, recently fitted a HKS pod. So I must have a loose clamp weaker thant he BOV spring rate when i shut off the throttle?
It actually sounds like the BOV exiting the atmosphere even so faintly.
I got distracted fitting 18" mags tonite. I'll check the clamps first thing before work tomorrow.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783055
Could be your BOV, happened to me once. It got stuck slightly open...
Coincidental that I hear it now that I fitted a pod filter!
Actually, first time I've ran a pod filter on a turboed car, so I wouldn't know.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783072
In that case, are you sure your not just hearing the turbo spool up?
Under what conditions can you hear the noise? If it's under acceleration i would say that is the case, the turbos just spooling like it should.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783174
Yeah those HKS pods are loud. My car sounds like it has a BOV but it's just got the stock bypass with an HKS pod.
The Mrs got pulled over a while back because the copper "heard the BOV go off". He had a look under the bonnet and conceeded that all was ok.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783916
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
