  • Replies 56
We're still in, although we may be a little bit late. And scuse 73ENA if she's a bit dirty, seeing as she's my daily driver now, she doesn't get the luxury of being washed on the weekend and sitting in the garage during the week all nice and sparkly, and i probably won't have time to wash her before tomorrow night...
MRR34 will make an appearence before it gets driven by a "older, smaller and rev friendly person"(thats mum) for the next 2 months.
Your hoon of a mum will have to come to the meets in your place while you're away then!
Of course! If you like chai's, just remember to byo bottle of cinnamon... :banana:
bottle? try tub or barrel, you've seen how much these guys use.... by the end they are chewing their chai's
I'll probably be in for this too, havent been around in a while
I feel your pain!!!!!
Can't make this one - I'm still off the road with a busted diff and tailshaft.......but hi to everyone regardless!
hmmm.. someone said he's not showing up but he did lol.. and drank 4 of the so called "tea" cai :P
He hammered them down real good! Put so much cinnamon, looked like cinnamon chai thickshake. haha Did you guys end up going for a drive?
