Sucks to be us, then... Find out Tomorrow if the one that is in Nth Qld is in good enough condition to use: fingers crossed... And I have to go back to the bodyshop (again) tomorrow, so they can finally get my passenger front window in the Stag working again. Stupid glass!
LUCKY YOU DONT LIVE IN NEW ZEALAND......this country has the shittest legal system, you can go and beat and murder people, and get the the most shittest sentence.....it applys to everything, from intentionaly breaking someones car window, to murder, increase jail time, people will think twice about doing the crime.....my rant
Its too expensive to keep someone in jail to be worth doing it for something that is considered just non-violent hooliganism with no real threat to anyones safety. You have to do something fairly serious to get time - and even then you really gotta get caught a few times doing it. Theres a fine line between stupidity and true criminals - they dont send stupid people to jail, only criminals - and i hate to say it but these guys who did it are stupid, but the courts will not define them as criminals.
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
