Well push has come to shove
Have had a little bit of interest in my Cefiro...but no takers so I have bitten the bullet...bought myself a cheap Cima and now I have gotta get rid of everything possible on the Ceffy so........place your offers, nothing is sacred on this car apart from what will fit on my Cima and offers will not be refused unless profoundly obsurd!
email me at [email protected]
or if your after a speedy reply
[email protected](possiblity is might get blocked by spam filter)
if outside business hours(after 5:30pm) then call me on 041 994 6415 or 9242 3443
if anything is not listed just ask, Im sure I have spares of alot of stuff as I had a front cut aswell and stripped everthing possible off it so have a spare dash and components.
If you want picture of anything, just ask me
Enjoy the Massacre of a beautiful drift weapon!
Standard RB20DET
Rebuilt standard turbo
with loom and ecu
Timing belt recently replaced
$850
RB20 5 speed
$350
Lightened flywheel with 3 puck Brass Button clutch
$300
price for complete engine and G/Box $1300
red K&N Pod
$20
Front mount intercooler with custom 3" steel painted pipework(small amount needs to be replaced) and stainless steel T-Bolt hose clamps
$300
Oil cooler with sandwich plate(universal model so will fit others) to fit RB20
$150
Suspension
Front Strut tower brace
$100
Height adjustable suspension
Fronts: JIC coilovers
Rears: Racing Gear coilovers
$750 The lot
Hicas Lock Bar
$100
Dr. Drift Alloy Pineapples
$75
Interior
Aftermarket gauges include:
Greedy temp gauge mounted on A-Pillar
$100
Splitfire Oil pressure and Temp gauges in centre console
$50ea
Matching aftermarket steering wheel, handbrake cover, shift knob and floor mats
$100
RECARO(Millenium Edition) driver's seat
$800
unknown turbo timer(1-3 minute)
$20
Racing pedals
$10
BLACK Aluminium GT rear wing
$75
Indicators
$100 passenger side
$30 Drivers side (cracked and scuff mark)
Tail Light Centre Piece
$100
Wheels
UNKNOWN aftermarket 3 piece Rims
15x7.5inch front and back
some ridiculous offset(hang a good inch outside the guards)
Wrapped in Federal's 205 20% Tread
Perfect for AE86
$1000
AVS 16" rims
7.5" & 8"
wrapped in poor quality rubber
$400
Edited by SideWaysChef
https://www.sau.com.au/forums/topic/214408-ceffy-has-gotta-go/
Will get you a picture of the cage if you like....but engine is in car so cant really be bothered pulling it out for a picture.
Will work out a price for the aircon dash surround after the weekend mate. Can't remember what it looks like from memory...has been a long time since I sat in the drivers seat of it
Got a pic of the cage and the flywheel?
Also how much for the plastic that goes around the air con on the center of the dash
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
