Goto http://www.au-hackershardware.com they have good prices and will send the chips COD so you wont get ripped. Of cource you still have to find someone to put it in, if you have an early model ps2 its a bastard of a job. It took my friend who is a l33t solderer 3 hours to chip mine with a messiah, he said it was the hardest thing hes ever done. It workes perfect though :)
https://www.sau.com.au/forums/topic/21448--/page/2/#findComment-455053
dont buy chips elsewhere will cost you more as we get them same price or cheaper than they do wholesale and add our installation cost, if u get it elsewhere u pay them wholesale + their profdit then our installation fee lol
and if it takes 3 hours to do a installation the dude is not l33t lol, i can do one properly all tested in less than 40mins (thats taking my time doing it properly) probably can do in 15mins if i rush
Bailylsd... get the messiah 2, please quote me the SCPH number form the back of your unit so i can give you a price (its difficulty changes the price as some models are harder/easier)
https://www.sau.com.au/forums/topic/21448--/page/2/#findComment-455790
v3s fastest ive done 1 is in 25mins... qwhich is pretty good, i usually spend 1 hour on a v3 to make saure those a-i wires dont come loose hehe... nice little fine bitches of legs those things are, u couldnt understand the hours ive spent tracing tracks to find alternate points for those dvd wires... they all end up on another chip with worse legs to solder to underneath!!! lol
but yer if ya wanna see me do a v3 in 25mins im happy to show you.. but i do charge accordingly :D
https://www.sau.com.au/forums/topic/21448--/page/2/#findComment-455866
  • 2 months later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
