im not following mate
top of tire camber correction is the same as using a camber arm
ill post up a picture of the wheel and tire before i did any adjustments on the suspension when i get home, i cant access it at work
it sticks out almost 2 inches from the fender.
only way i could htink of doing it without alot of camber on my particular car, woudl be to get the rear axles shortened, grab some ikeya formula rear LCAs, and adjust them in, along with the Upper camber arm, which would bring hte hub in further, allowing me to run lower offsets without as much camber.
  • Replies 89
For shorter drive shafts have a look through the Nissan range, lots of them are splines interchangeable. Stuff like LHS Cefiro into RHS S13 to faciliate wider wheels, an R32GTST cradle into R32GTR etc etc. A bit of homework and I doubt that you would ever have to get a drive shortened.
Cheers
Gary
true most liekly
BUT, the reduced camber would defeat the purpose of the camber
VIP.....
OK now I am confused, the VIP look I am familiar with is low and wide with dish. The camber is not the look itself, it is an unwanted (undesirable) consequence of trying to achieve the look. Which, with a bit of engineering, you can remove.
Cheers
Gary
lol
dude, i have s13 traction rods
r33 tie rods
s14 suspension parts
jic from tophats
stock rears
ksport coilovers (complete ass)
gtr tranny
s14 subframe
and a homemade exhaust
not to mention my intercooler mounting.
my shits ghetto
Cheers
Gary
there are three fundamentals (well that the owners of garson, junction produce, and mode parfume told me at toyo auto salon)
Low
Fitment
Camber
without those three items, your not truely within the VIp style "parameters i guess"
VIp is a popularity contest on who can spend the most, be the most aggressive, or for somet he cleanest
I chose the old school huge wheels and camber route
i mena, i could have kept some 10j -5 or so wheels and had maybe -5 or 6 * of camber BUT i chose to do stuff out of hte norm for most gaijin, and go old school.
Regardless it is a style, which is next to drifting in japan, and quickly becoming the largest up and comming "fad" in the US.
i kind of like the fact it takes alot of money and dedication to do hte more extreme stuff in VIP, it weeds out the poseres
regardless
Lets stop the bickering, i dont mind you, your a smart guy. Im 22, i am hard headed. Just the way it is
hey grant if think theres still hope for you yet!! you will find we are definitly not into US fads, we do'not cut & shut, we are into function and practability, everyone to there own but down here mate were into go not so much show(sure we want to look good but more importantly we want to drive good), we are lucky on this site to be able to access great advice from experienced people, mate you say your only 22 and hardheaded, sure thats ok but you have to know( as you guys say) when to hold em' & when to fold em'
cheers leigh.
Wow, this is all really excellent stuff, but I'm afraid I am now completely lost.
I have free r33 gtst struts (I assume these are in their entirety: springs/asshats/whatever)
Can I put them on the Stagea, and will they keep me on the road?!
If you can get the rear Stag hats on the rear R33 shocks.
No. The only thing that is any use to you are the rear shocks and the front strut tops, everything else is wrong.
Cheers
Gary
i mean, im not arguing anymore
i have r33 on mine, i know i can make it work
BUT he should explain in one post, why it wont work for the guy so he knows why
I'm not normally one to rock the boat, but I agree with Grant that a 1 post explanation could be helpful: I'm getting a little lost on this as well: too many side issues and tangents!
That said, Grant, you should take a leaf out of your own book: when he asked if they'd fit, you merely said yes, with absolutely no mention of what parts needed to be swapped and changed between standard suspension and the shocks he has coming. If he had just taken that advice at face value and pulled his car apart, there would have been an extremely rude shock for him to discover that he then had to modify the new suspension (albeit with parts he would have sitting there from the std stuff) before he could put it all back together. It wasn't until SK and yourself started discussions that it became clear that it isn't a straight "whip out the old ones and slot in the new ones" process.
Just my 2 cents' worth...
No offence tintended to any involved: this is merely an observation from someone who is pretty mechanically inept.
That would be achievable, if somebody didn't nit-pick apart things and blow this thread out into 100 posts. :D
It was explained earlier.
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
