hey guys im looking at buying a R33 series II GTST was wondering what your fuel consumtion is for city / freeway and babied vs lead foot.
could you include the type of mods u have on ur skylines as well please?
i am hoping to find one with not much more then an exhaust on it mayb an intercooler?
and do intercoolers inc fuel usage or just power out put?
thanks tim
https://www.sau.com.au/forums/topic/214815-fuel-consumption/
one of my mates has a 33, full exhaust HKS pod and thats about it, goes prety hard he has got up to 620k's from a tank but if your buying a turbocharged performance car fuel consumption is something you can not really expect to be brilliant
i understand that being a turbo 6 its going to use fuel but i would imagine that with next to no performance mods on it and babied it would not use much more if not less then my VT commodore i have atm.
how does an intercooler affect fuel consumption? i would have thought it would decrease the amount used becuase the cars gettin more power from the same air flow
i guess it would be similar fuel consumption, from memory your car at the moment has 147 kw and is probably automatic and is about 1300kg i suppose, 33's have 171 i think will probably be Manual and are about the same weight so the power to weight ratio is better so the engine does not have to work as hard sooooo in theory should be more econimical but when the boost bug bites your foot gets heavey!!! as far as an intercooler goes if you can get the air cooler it should be more dense but im not sure it will improve your economy as air fuel ratios are all pre programmed by the ecu. i guess it would require some research.
cool so yeah i suppose it should be similar consumption but needing PULP will cost a little more, i have found BP fuel to last the longest, run the smothest and gives just a bit more power, that might just be me but most of the people i know with turbo cars agree
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
