STAINLESS STEEL HIGH PERFORMANCE RACE/STREET
CATALYTIC CONVERTER 3" HI-FLOW NEW
New Top Quality High Flow Ceramic Universal Catalytic Converter.
This has 3"ends 11" long and 4" round Universal OBD II compliant.
Don't let your stock converter slow you down. If your looking to open up your exhaust flow and get some free Horsepower, this Cat is for you.
This converter is one of the BEST in the Industry, it is made from T-409 Stainless Steel - Won't Rust, can be polished, can be slip fitted, or welded, are compact and light weight, and out flow most other aftermarket converters.
This high flow converter features a ceramic brick with 300 holes per square inch.
Offering better Performance and Flow, in some cases more than 50%, than comparable converters, and sometimes costing hundreds less...
The end veiw picture shows a standard flash light shining through the core, that's free flow capability.
Also dissipates heat better due to there design.
Don't be fooled by some other lower priced, welded together units, or some second rate knock off, these are OBD II compliant.
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Brick Type - Ceramic
Price $200 negiotable
Edited by bazr33
i am finding out the information for the above questions at the moment.
I am unaware of flow and brand, as i only wanted it cause my old cat was hitting the floor of my car.
As i found out the old cat was only hitting by mm's i just put a dent in the floor and now it misses.
I have pulled the cat out of the box and it looks of high standard quality.
Hey Zennon
The brand name is Thunderbolt they are an American Hi flow converter.
I do not have the flow rate.
I do have the CPI(cells per sq. inch).
The ceramics are 330cpi
Thanks
Sure?
Thunderbolt: http://www.performance-curve.com/index.asp...amp;ProdID=1172
Other: http://www.performance-curve.com/index.asp...amp;ProdID=1060
GL with sale anyway
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
