Hey guys, im having a real deliema, i just bought some of this Redline shockproof 80w140 the red stuff. Now i have chucked it in the diff and gearbox.
The problem im having is that it still feels like my gearbox is really tight. As in getting the gears in. Sometimes they feel like they are crunching to get in.
What do you recommend for gearbox??? or should i stick with this stuff?
Also I can really smell this stuff its really strong inside the car. is that normal??
Also its for my 34gtt. and i also have a short shifter.
Cheers.
sorry found right section;
Edited by R34ZOR
https://www.sau.com.au/forums/topic/214933-redline-shockproof-80w140/
80w140? This is similar to the Redline shockproof, is that what your using? Most people use lightweight shockproof.
I've seen MT-90 recommended although I'm going to try MTL first...
http://performancelub.com/Redline%20pricelist.htm
damn straight the short shifter will be making it worse.
but gearbox takes smurf blood. the human blood is for diffs not gearbox
although tecnically they are both gear oils...I would not be putting the red one esp. at the visc in the GB.
just oils with the appropiate friction modifiers. I use MT-90 redline...I found it better than shockproof as it too is really a gear oil.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
