Item: brand new Haltech e11v2 ecu and wiring loom + 3 bar map sensor
Age: unused in boxes
Condition: brand new
Price: $1800 for ecu and loom and map sensor
$480 for haltech ls1 coilpacks
To Fit: (What car) any car
Contact: PM for further details
Comments: The Haltech e11v2 is the latest ecu from Haltech and has all features you could ever need, i bought this a few months ago and planned on using it but i changed my tuner and therefore kept my old ecu setup as the new tuner was more familiar with it. I started to make the wiring loom for my rb26 engine so the loom is 50% finished with rb26 plugs on it, but these can easily be changed and wired into any car/motor combo. the ecu comes with a haltech 3 bar map sensor as well, i paid a total of $2340 for these parts brand new), im asking $1800
Coilpacks are brand new as well i made a bracket to mount these under coilpack cover on the rb26 and ill give that in the price if the buyer wants it, they are really good coils and made for high power application (i was planning on using these with 600rwhp+). These were $650 new. Im asking for $480 for these.
i have reciepts for all these parts if the buyer wishes to see them as well.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
