Now I'm not going to name names as that would be classed as a VV. I'll just say the first company is a few drift kids who think they know what they are doing and the 2nd company is a race trans/diff place that has been in business for a long time. PM me if you want to know details, I'm located in SA.
Ok to start with I have a HR31 skyline with a Longnose R200 diff, to my knowledge it was a stock clutch pack LSD, it was not noisy or clunking at the time it was just open wheeling badly. Now I've heard of people successfully just 'shimming' these tighter to get some life out of then, now it happens that a fairly new workshop had opened up and were offering to do this on the cheap.
So I take it down there and they open it up and find out its actually a nismo 2 way that has worn out clutch packs and can't simply be shimmed, they offer for a cheap option to put in a shimmed up stock LSD centre out of an s13. They do this and charge me $250 and give me my 2way centre back.
About 10mins driving later the diff makes a horrible whining noise, the sort you get with incorrectly set backlash. I take it back as soon as possible with minimal driving in between. During this time it has popped the driveshafts out and lost over half the oil. On inspection the diff appears to be fine.
Around now is when I start questioning the skills these people have, and asked if they knew how to set the backlash, the guy seemed pretty clueless and ended up taking it to a diff shop down the road and getting them to fit it (at his cost). He reports back that my crown and pinion are now very worn, his explanation was that the crown was already worn down from age and putting the tightly shimmed centre in it has finished it off. The diff shop I'm assuming then properly set the backlash and made up a proper shim for it.
The guy recommends that I take it to this other company and get the 2way properly rebuilt as they know their shit and have been in the business for 40+ years.
Now at this point I leave with a noisy diff that acts like a cheap locker, about 2 days later its almost as loose as it was before and I have essentially spend $250 to ruin my diff.
I go to the new place that he recommends, they rebuild the nismo 2 way centre at a very reasonably price ($150), however when they go to fit it it is still very noisy, they say that as the crown and pinion are so worn I either have to replace them, or buy a complete 2nd hand diff assembly and use a set from there, or drive with a noisy diff but a strong centre (2way) that should last. They quote a complete diff assembly ~$700 including fitting etc, after speaking to this place they seem to think that they have just stuffed up fitting the shims and set the backlash incorrectly ruining it.
Now the question I ask, how liable is the first company, I think it is reasonable to ask for my $250 back and return the other centre, however you could also argue they are liable for replacing the gears as they did not set the backlash correctly and ruined them. What do you people think I should do, take it as lesson learnt and just get my $250 back, or pursue partial costs of the replacement gears as well?
2nd question, please PM me if you have a longnose R200 diff with a good gear set, eg not noisy or clunky, dont care if the centre is stuffed, open wheeler etc.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
