Hey,
Just wondering if the DIN panel from JustJap fits straight into the console of a R33? Im planning on putting gauges under my deck (nothing is there at the moment) and was gonna make up a bracket to hold them. Although now ive seen this on JustJap and if it fits straight in that would be perfect!! Comes with 3 Gauges and a bracket to hold them!
Thanks! :blink:
http://justjap.com/store/product.php?produ...=267&page=1
Oh Really.... How come it didnt look good? Was it hard to fit? What did you have to do? Will I need to make up any brackets or does it just bolt up really easy?
so many questions! hahaha, just not sure how it would fit in.....
we just placed it in, didnt bolt it to anything. it will slip in behide the plastic bits of the dash (if you get what i mean) the reason i didn't think it looked any good was because the gauges dont sit flush. plus Chi used the cheap autometer gauges too which i think like crap in my opinion.
i will pm chi and get him to post a pic up for you
How come it looked bad? Was it a good fit?
I thought having 3 gauges under the deck would look good!
How did u install it in there? I dont get how people say they slide it in there? how does it hold in position? lol
So where did you end up putting it in the dash? Do you have a pic? :thumbsup:
yeah it did look crap cause it didn't sit flush hmmm i havne't got any pics it was ages ago but gotta thank mikey again for coming over and being my back yard mechanic !!! hah yeah man just get the defi 3 guage combo from nengun for like 400 or and it sits flush and looks great :thumbsup: +1 on china guages being crap hahah gimme ur apexi ones mike !
Autometer are a good brand for gauges... its the autogauge which are dodgy.. which are the ones that just jap are selling...
The GTR torque gauge shows how much is being transferred from the rear to the front end of the car, since it has an all-wheel drive system...unlike your rear wheel drive only GTS-T.
The 32 GTR one shows Voltage, Oil Temp, Boost, so might be more useful... but I'd get the defi one if I was you http://www.nengun.com/defi/din-gauge-rhd
Just noticed that the R33 GTR DIN gauges replace where the aircon unit is on the GTS-T. Will the aircon unit fit in another slot easy enough? Just wondering becasue the top slot has a corner on it.
Cheers!
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
