Hey guys,
I have a 180sx with a RB20DET in it Mines ECU, Cooler and a zorst.
When i got the car i used to feel it pull hard when i put my foot down, now days i do and i dont even get that pull feeling.
I have checked out for any boost leaks and there is none.
Im thinking it could be coil packs or spark plugs?
Any thoughts?
https://www.sau.com.au/forums/topic/215639-motor-out-of-puff/
lol im not too sure about this but how long ahve you had the car for??? if only a short period of time and your quickest car so far... uve just gotten used to that feeling of boost and the adrenalin doesnt flow as much...
happened in my rb20det powered vl wagon and my gtr...... just feel slower after a while..... just baby it around all week under 3 grand then at the end of the week have a spireted run and it will feel quick again :D
happened in my rb20det powered vl wagon and my gtr...... just feel slower after a while..... just baby it around all week under 3 grand then at the end of the week have a spireted run and it will feel quick again :)
Thats one more advantage of a daily driver.
I drive a 1.3L Corolla to work, mates places, parties, just about everywhere pretty much.
When there is a track day on or if I get an itchy right foot I have a 285RWKW R32 in the garage... And it feels stupid fast even whilst wheel spinning through the first 3 gears :D
When you have a daily driver, the novelty of your track car just never wears off. :D
R31 Nismoid is spot on. You'll most likely spend forever working out what it could be. There's so many components that can get tired and reduce performance. A dyno run and some analysis by a tuner will tell you what component is tired in a few minutes and isn't expensive.
About how much would it be?
The only reason why i said coil packs or spark plugs is because i read a while ago some one said eather coil packs or spark plugs can cause this and i have not changed them since i got the car and i dont know when the last owner did eather.
Edited by raZ1911
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
