hey man nah havent lowered it :s ..i thought it looked like it tho in the pics
made 101kw :s thought id atleast get 110kw..i duno tho...i havent had 100k service done n im well past due for it..117k
but yeaa :s i needa get a CAI happening, cause i just have a pod in a box atm.
whats mods you got 123kw fair amount for a n/a.
yeahhh autoo lol
Is that all? just a pod no exhaust? If so 101 probably isn't too bad..pretty sure they make around 91 stock standard... oh and i'd be getting that 100k service done...a busted timing belt can be pretty nasty, prevention is better than cure, unless you want an excuse to do a rebuild :P
101 is good man its just that mines manual i think gets a bit more power to the wheels
i just had a pod in no box or anything (lazy) and catback exhaust
pods off now though got defected for it not being secured properly
Yeah when i first dynoed mine it was running like shit, spark plugs/coilpacks on their way out and being an auto it only pulled like 95rwkw lol
havent dynoed it since but i expect it to be much better :ermm:
Is that all? just a pod no exhaust? If so 101 probably isn't too bad..pretty sure they make around 91 stock standard... oh and i'd be getting that 100k service done...a busted timing belt can be pretty nasty, prevention is better than cure, unless you want an excuse to do a rebuild :ermm:
ey i got pod in a box, extractors and 2.5 inch exhaustt with cannon on the back
hopefully once i get 100k service done it might run like it should which im hoping is better, what sort of parts could be affecting its actual performance, anyone know what price range is on a 100k service?
Have a grand ready for the 100k service. They replace the water pump, timing belt, and the other usual stuff. It's the labour involved in such a service. Still though, the cost of a 100k service is nothing compared to that of a snapped belt resulting in anything from bent valves and other expensive engine repair.
When I bought my R34 I was told that the timing belt had been replaced already. I didn't take the chance, got it changed, and sure enough it was the original very worn factory timing belt. Make sure you get the idler and tensioner pulleys as well as seals.
Anything can affect the performance really, from spark plugs, to coil packs, the fuel used, the cat could be holding it back due to age, air filter might need cleaning...a lot of variables really.
What fuel do you use?
Also keep in mind not all Dyno's will report the same. I've known of some cars to read out anywhere from 10-20kw different between dynos. You should always use the same Dyno when measuring performance between modifications if you're wanting to see the comparison.
nathan is spot on there, had the 100,000 done on my 33, cost just over a grand. water pump replacement is optional fyi, i opted to get it done thoe as they tend to show their age as they approach the 100,000 mark. well worth it.
get nissan to put their full synthetic oil in it too, unless you wanna use your own. apparently its good, costs $40 for 5L (got a quote today)
I try to time my services with major upgrades =] My last service coincided with my conversion, works out bit more worthwhile then.
Check out some of the sponsors, I know there's some that do the 100k service drive-in-drive-out quoted parts supplied. I done mine when I was still relatively new to Queensland and ended up getting a mechanic referred to by work mates to do mine. Got my timing belt kit from CRD (Croydon Racing Developments). My mechanic said my water pump still looked good till probably 150-180,000 kms at which point I'd might as well do the timing belt again. By the time I get to that sort of mileage (I've done under 10,000 in the last year) I'll be ready to take performance to another level and do a rebuild anyways, so I didn't worry about the water pump at that stage particularly when cash flow for me wasn't at its best.
If you're looking to get adjustable cam gears, that's a good time to do it since the cam cover and belt is off and they're changing the seals. I wish I'd tried to squeeze in an adjustable exhaust cam gear back then, would have allowed for a bit more fine tuning.
Edited by N-DAWG
  • 2 months later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
