Great angle shane'o!
Did you manage to hold onto it?
Lol.. what is that to the left of your car?
An under tray?
Drifting seems to be an awesome way to loose weight out the car.
Last time I went, I had 3 interior pannels rip/tear/break themselfs off the car
Edited by GTS4WD
An under tray?
I'm pretty sure I held it, I cant remember spinning on that corner at the last few days I have been to.
That thing beside my car is most likely a tyre carcass...
I haven't had any real damage done to my car while drifting, only a bit of paint missing off my front bar and rear bars from just scraping tyres/barriers...
Oh and they dont like it when you do this :P
dirt turbo :P
What diff is in it?
It is a Nismo 2way mechanical, it has a 4.083 ratio (same as the original auto diff that was in the car).
Bought it second hand in housing for $650 just over 2 years ago, have put over 30,000kms on it and it hasn't missed a beat
everytime i see this stupid thread i ask myself 'what is the difference in looks between a non-turbo and turbo car? (apart from pissy little brakes)'
My car came factory with turbo spec brakes, so the difference is zilch.. apart from the 3inch to the muffler that you can see on skylines coz the ass is so high up.
My R34!! with my nephew rex
its funny how your on ur red p;s
and ur nephews full lisence :)
Here are a few of mine, had it resprayed a few weeks ago and had the bodykit fitted. Used to be blue over silver 2 tone, now its a custom blue with 2 pearls: purple and green.
post-9734-1196398516_thumb.jpg what the colour actually looks like in the sun.
love it
Here's some pics of my n/a 34..... i've been gettin mixed opinions on if i should lower it... any thoughts?
nah ride height is good
God I hate Hot4's...
... Their need to plaster every page with half-naked girls detracts from the point of the magazine - the cars. So glad HPI & Zoom don't do that shit.
i dont buy it at all. only got it cause my mate told me my 34 was in it....
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
