Make:Nissan
Model:1993 R33 Skyline
Milage:115 000
Transmission:5 Speed
Colour:Maroon
Complied?Yes
RWC supplied?Yes
Currently registered?Yes
Price:18'000 ono
Contact: lachlan 0400959464
Comments / Modifications:
CP Forged Pistons
Eagle H-beam Rods
ARP Rod Bolts
Ported And Polished Head
Cometic Head Gasket
ARP head Stud Kit
Balanced Bottom End
Heavy Duty Valve Springs
OS Giken Cam Gears
Excedy button clutch
550cc Injectors
Apexi Power FC
XTR GT35R On Stainless Manifold
Tial Wastegate
2ltr Surge Tank With Bosch 044 Fuel Pump
Cooling Pro 600x300x110 Intercooler
Custom Cooler Piping
Alloy Radiator
Full Leather Interior
White face dials
Blitz Turbo Timer
Pioneer head unit
sony Xplode amp
2 alpine 10inch 500w(In the parcel tray)
Just Had a service and a tune made 411hp on 16psi with knock levels under 25
Images:
Edited by asus
https://www.sau.com.au/forums/topic/215878-for-sale-r33-skyline/
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
