I spoke to Russ on Friday on their way to super lap and he was pretty confident Mark will bring the car out in the afternoon and run some laps !!!
We dropped the Dyno out there tonight, all set and ready to go.
This is going to be a huge day guys, can't wait !!!
Dried out for the afternoon session and turned into a pretty good day. As always, extremely well organised and run by Paul and the people who volunteered their services for the day. Many thanks!
Thanks to Dave for his sick as Handle-less handless jack and his trolley jack. Thanks to Pear and his trolley jack as well, And thanks to Jay for the lending us some random tools during the day.
Kudo's to the time attack boys and girls, very well set up event
Edited by Nismo_Boy
+1
the na s15 wouldn't have been possible without you :P
saved me the cost of a tow truck, thanks again guys
+1
the na s15 wouldn't have been possible without you :D
All good mate! hope the repairs go well.
was a bloody great day!! can't wait for the next one.
Big THANKS to Paul and ALL the sponsors! (Link International and Mick from Signature)! :D
also a big thanks to the SAUQld guys that helped out with the BBQ (Jay, Lee, Eug, etc...) :)
finishing the day on a high - R35 GTR out on the track - it doesn't get any better!! :ermm:
looking forward to seeing more photos and vids.
Thanks again Paul!!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
