I spoke to Russ on Friday on their way to super lap and he was pretty confident Mark will bring the car out in the afternoon and run some laps !!!
We dropped the Dyno out there tonight, all set and ready to go.
This is going to be a huge day guys, can't wait !!!
Dried out for the afternoon session and turned into a pretty good day. As always, extremely well organised and run by Paul and the people who volunteered their services for the day. Many thanks!
Thanks to Dave for his sick as Handle-less handless jack and his trolley jack. Thanks to Pear and his trolley jack as well, And thanks to Jay for the lending us some random tools during the day.
Kudo's to the time attack boys and girls, very well set up event
Edited by Nismo_Boy
+1
the na s15 wouldn't have been possible without you :P
saved me the cost of a tow truck, thanks again guys
+1
the na s15 wouldn't have been possible without you :D
All good mate! hope the repairs go well.
was a bloody great day!! can't wait for the next one.
Big THANKS to Paul and ALL the sponsors! (Link International and Mick from Signature)! :D
also a big thanks to the SAUQld guys that helped out with the BBQ (Jay, Lee, Eug, etc...) :)
finishing the day on a high - R35 GTR out on the track - it doesn't get any better!! :ermm:
looking forward to seeing more photos and vids.
Thanks again Paul!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
