The first “Annual TimeAttack Nissan Meeting” will be held in the afternoon session of the July 8 Time Attack track day. I’m excited to announce that Link International Pty Ltd is the proud sponsor of the event. Link International are the official exclusive distributors of:
NISMO Competition Parts
MOTUL Performance Oils
BMC Air Filters
During the afternoon there will be lots of excitement on and off the track. Drivers will run against the clock on the Sprint Track and each driver will receive a limited edition event shirt. Off the track there will be Motorkhana action in the carpark along with a dyno shootout. There will be prize packs, give aways, demo cars, D.J. and trade displays to keep drivers and spectators busy all afternoon.
Track Event: $110 (TimeAttack paid members $100)
Motorkhana: Free for track drivers, ($20 to do separately without track. Come along and have a go)
Dyno: $TBA
Further details will be announced as they are finalised.
Time Attack on the Sprint Track
Limited Edition Event Shirt
Trade Displays
Prize Packs
Give Aways
Motorkhana
Demo Cars
Dyno
D.J.
To book, make sure you have joined www.TimeAttack.com.au
Your spot will be confirmed once your deposit has been received.
Paul Ruzic
  • 3 weeks later...
  • 4 weeks later...
Only a month to go now. The Signature Performance dyno has been secured for the event. $15 for 2 power runs for Track Drivers and $25 if you just want to be dyno'd. Special thanks to the sponsors for organising such great pricing !!
i wpould love to come but may not be able to with superlap 3 days before.
i'll bring the r33 if it's going!
Just do it or I'll beat you senseless. :wub: Still want to have a bo peep at that hydraulic setup too Russ. :(
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
