S13, S14, S15, R32 Gtst & Gtr, R33 Gtst, Ca18det, Sr20det Red Top And Vvti, Rb20et, Rb25det, Rb26dett
Okay ppl I have a heaps of parts to get rid of
1) SR20DET Red top Engine, It has inlet manifold, alternator, power steering pump, complete head, block, crank rods and pistions, sump. There is no turbo, exhuast manifold, throtle postions sensor, loom, computer, distributor or coil packs. This engine had number 2 conrod cap come loose and jam the engine. There is no damage to the crank, block or head but the cams are worn.
Perfect for a rebuild
$300 ono
2) SR20DET Starter motors x2 $100
3) SR20DET Starter motor with loom x1 not sure what speedo plug this is for my guess is that it is for a S14 5 speed $100
4) Passenger S13 side guard $50 there is a small dent
5) Clutch master cylinder to slave cylinder pressure line $50
6) CA18DE standard ecu $ free
7) Standard S13 front castor rods $ free
8) S13 front head light projector style $ free
9) Standard RB25DET exhaust manifold with studs $50
10) 180sx front LHS head light cover painted mat black and straight $50
11) S13 airconditioner condenser and dryer straight with not many bent fins $20
12) S13 standard front sway bar with good bushes $20
13) S13 CA/SR engine cross member $75
14) R32 RB20DET engine cross member $100
15) O2 sensors 3 pin x2 $50 ea
16) Standard S15 side mount intercooler with all piping $100
17) S13 HID instrument cluster with HID attachment speedo is at 105,649km no Tacho works perfectly $ 50
18) R32 GTR matched set crank, rods and pistons $200
19) S15 SR20DET VVTI head complete in fair condition $750
20) S15 SR20DET block bare fair condition $350
21) S15 SR20DET crank fair condition $150
22) S15 SR20DET standard injectors with rail and reg $100
23) S15 SR20DET Inlet manifold top and bottom $50
24) S15 SR20DET oil pump good condition $50
25) S15 SR20DET TPS excelent condition $50
26) S15 SR20DET harmonic standard balancer $50
27) Walbro 550hp intank fuel pump new still in box $150
28) SR20DET viscous engine fan $20
29) S13 brake booster fair condition $50
30) CA18DET igniter pack $ free
31) SR20DE distributors in excelent working order x2 $75 ea
32) S13 SR20DE engine loom complete un cut/murdered $25
33) S14a SR20DE engine loom complete un cut/murdered $25
34) RB25DET engine loom complete un cut/murdered $50
35) Complete S15 SR20DET VVTI in parts all that is needed is bearings and gasket kit. comes with ACL 20 thou over sized pistions with hasting pistion rings on standard rods with ARP con rod studs, complete head with port job and standard cams, freshly honed block and excelent crank, fresh oil pump and chain, fresh chain tensioner, standard harmonic balancer and engine mounts etc.
No turbo, distributor, coil packs, loom, computer, flywheel.
$ 1,250
I have pictures of all parts but my camera is to detailed and the pictures are upwards of 2.5MB so pm me your email and wahat your interested in and I'll send them to you. Sorry about the inconveniance
All prices are negotable pm me on here or call me on 0406 046 136
I'm located in Ipswich QLD.
Cheers
Luke
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
