Make sure you buy one thats been serviced at a mazda dealer that way you know everything has been done on time.. and if you can buy one still with some warranty.
The major services are every 40,000kms and the are upwards of $450 but all the other services should be below $280 so long as you dont have any extras needed.
They are a good car though.. and i'm not just saying so because i work for Mazda :thumbsup:
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3828246
get the mazda 3, i work for them and we barely have any probs with them. we get sum that come in and they say they get around 600 - 700ks per tank of fuel. the best ive heard is 1000ks per tank.
I can vouch for that. Very nice car. The Mazda 3 Maxx Sport never gets under 600k out of a tank, typically I get more than 660k per fill. They drive with mercedes like handling, and have enough power in the 2.0L petrol variant for driving to make it satisfying to drive without planting the accelerator. And most impressive of all they are quiet, and stay quiet after a few years too!
The car is very handy with the roof racks on full time, still very quiet, and tow bar too.
The ONLY SINGLE fault and enough to make me rant about it that I can make of this vehicle is the air conditioning,
which I have been told needs to be changed to a custom aftermarket solution for the condensor panel to make it blow hard and cold.
It is cold enough to maintain a comfortable temperature just not strong enough to do something like bring it down to sub 20 degrees celcius on a 38 degrees celcius day.
A typical summer day like that and it will sit at a constant 23-26 degrees on the freeway regardless of the a/c fan speed setting.
I need an air conditioner to go to at below 20 degrees no matter how hot it is outside. This is because after exercising running around and run back to the car, I feel sweaty and need to cool down to get rid of the humid feeling.
I guess this car was made for Japan with the expectation that you will park your car in an undercover car park during the day at the office, not for active Australians, who have to leave their car in the sun, and who after doing so and driving for 2 hours will expect to eventually cool down in the car, which will never happen in this car.
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3828319
Mazda 3 is a nice car,
was almost going to buy one... then on the drive to the mazda dealership I spotted a sleek looking car on the corner of a car yard, turned out to be this quirky thing called an r33 skyline.
ended up buying the skyline (talk about a completely different world) and started my love affair with imports, was never a big fan of cars before then. Go figure
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3828942
lol I was going to buy the mazda 3 as well, never ever heard of a skyline b4 that
but whilst browsing on the net, I found this awesome looking silver s2 skyline
went for a test drive and all that practicality shit went straight out the window :D
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3829753
went for a test drive and all that practicality shit went straight out the window :down:
Well I just sold my Skyline after two years of ownership and really need to find a cheap to run but nice and reliable car (looking to spend between $16-$23K)
Im also buying a house soon so hence why I cant really afford to keep a fuel hungry PULP drinking car.
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3830763
yeahthey will get that all the time. we always get people that ask about the a/c with them but the way 2 get them realy cold is have them set on recurculate instead of fresh. we have tested 1 car that on a 34 degree day we had the ac sitting around 7degrees.
https://www.sau.com.au/forums/topic/216714-mazda/#findComment-3833912
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
