So I figured I'd make some sort of photo diary of the work being done to my car at Driftline down in Campbellfield, VIC.
Having hit a runaway gate at DECA (thanks for securing the gate with a watering hose... real intelligent) a year n a bit ago, the car's been looking a little sorry and often referred to as the ghetto R32. but no more... with a fresh lick of satin black, full kit, flared fenders and some other bits, it should come out looking mint.
So first the raw materials:
Take 1 beaten up R32
Add:
1 bonnet
2 pumped D-Max front fenders from Empire Aero
2 pumped rear fender flares from Viva Garage
1 Type J Front Bumper from Viva Garage
2 vertex sideskirts and rear bumper from Viva Garage
1 open grille, 2 GTR grill clips, and 1 V-Spec bonnet lip from Laurence (gojira/dr1ft.jp)
a set of Work VS-XX in 17" by custom offsets to fill out the fenders for flush fitment
Wheels have been taken apart atm to have custom outer bands machined and have the centres powdercoated black to match the car.
Update (from a while back):
https://www.sau.com.au/forums/topic/216749-my-epic-r32-rebuild/
  • Replies 41
Posted Images
funky... nice work on airbrushing yourself onto your bonnet! looks like a reflection!
well picked sir... but a flaw in your theory... i'm not a japanese bloke missing my torso.
the guys at the workshop decided to fit up the Viva Garage supplied rear quarters today.
I got an abusive phone call from Roshan, for supplying shit quality quarters that didn't line up with the door line or boot line. His options were "throw them away... or cut them up and make them fit"... the latter will cost a lot more time, which we don't have, so the hunt is on for better quality flared rear quarter fenders.
He said he took some pics of it on the car to show how horribly out they were. Should be interesting.
for sure, should've gotten the rears from Empire Aero as well along with the fronts... but we had already ordered the rears from Viva, so that's why we're in this predicament. Contacted Empire about getting rears as well... lets see how we go.
well just to update, today we decided to chop the Viva gaurds (remove the lips that are supposed to go under the boot and door etc) and redo the glass.
Haven't decided on how to blend it... a full blend will require the windows out etc... which is a long and complex process. probably won't go with the option... this means we'll have to go with a more ghetto look for the rears, with the panel edges visible ;)
thats not very Epic Shan..
go the whole hog .. no point spending the cash for a ful spray and leave that little bit bugging you forever.
if we were to take the glass out etc it'd extend the timeframe by two weeks... its the main deciding factor...
we're gonna try and do some tricky stuff to blend it in... without blending it in. it'll either turn out shit... or epic ;)
the respray is only the outer panels and edges n door jams etc... engine bay's already black as is the inside of the boot etc...
the other alternative is to flare the metal out... but cos of the track damage on the driver side it's pretty hard... easier to just cover the battle scars with fibreglass.
  • 4 weeks later...
lol the P plates was a shock to me too... then I realised I had to get my cuz to drive my car to the shop cos I was in brissy, so he had to put em up. hope he didn't munt the clutch like last time by riding it.
i recently brought a full r32 viva garage kit from a friend for $200. i will be throwing the sideskirts away as they are so bull shit its not funny. rear bar was the best fitting after i cut and shut it heaps and the front bar needed a fir bit of time aswell. well the front bar was almost straight. had to fold the sides in heaps. pretty crap realy. worse for the bloke i brought it off as it cost him $1200 and sat in his shed for 12 months.
sorry to hijack just thought i would emphasise that fact
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
