Sau Lan 23rd May
The tuner I'm going to is reputable and has a lot of experience tuning road cars as well as race engines. I doubt he'll have an issue with it. I slightly adjusted the idle and cruise AFR targets so they get closer to what they're supposed to be but I'll let the expert correct the tables as I am way too inexperienced.
Oh, probably worth mentioning as well, my mixtures are perfect at idle. -
If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well. -
It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
