  • Replies 196
Posted Images
geez I can't believe all these softc0cks pulling out .... oh hang on, I can believe it:
haha you beat me to it Steve - as per normal SAU events, just over half will actually turn up. The rest will come up with pathetic excuses like 'I completely forgot about it and went out and got smashed', 'I slept in', 'I couldn't get away from work' etc etc :)
:):D:huh:
See the rest of you guys who bother turning up at Scoozi for a latte at 8pm.
lol oh wise one andrew :)
shane finish up when your tired
Joel you able to at least make coffee :D
blue is a pretty colour look @ the highlites in my signature :)
anyways im off getting dressed and picking up Mark
hahaha yeah the inaugural SAU:SA lan was awesome .... sorry I couldn't hang around longer, but have to do the right thing by the wife and a teething 7 month old :)
Great to catch up with some old faces, and meet some new ones!
We will have to make this a regular thing! Thanks heaps ArenaGTR for putting it on, and Steve for his organisational skills.
not too sure who the champ was but it wasnt me hahaha
thanks all was good fun and something different! once again cheers for the lift steve pleasure to meet ya
Arena, thanks for havin us champ!
:P
was a good night. good catchin up with the usual suspects and meetin a few new ones.
hows that investigation coming pete? :P
surprised pics of cs:sauce havent come up yet. there were quite a few people with their phones/cameras out.
and mark, you are freakishly good at starcraft. i mean, goddamn.
lookin forward to doing it all again. :(
no worries all, was good to have you all there, sorry I couldn't spend much time playing games with you guys cuz we were literally packed out, so I took my shisha out and smoked it instead :(, and kietz, I think u got the wrong way around, "if you can't beat kietz, u can't beat me" =.='|||
definately gonna organise this event on a regular basis (/me looks @ Steve - thanks laahhh)
Thank you for all that came to the event, was great fun uleh, I pwned hard in CS: Source muahahaha (old & rusty), but anyhow, thanks again guys.
P.S. Was that Sled @ Arena? (ELLO THERE) he's so big and tall, was afraid to go up to him and say hi :P
Edited by ArenaGTR
i heard about said sauce incident. cmon guys where are the pics?
cheers to steve and Arena man, was good fun even though i got majorly whipped. Never played at 1 those things so it was something out of the norm.
i cant believe jenkies whipped us all at the same time at starcraft wtf. i think next time ill make more towers, atleast i made you take that extra 3min to beat me the second time.
CS kept getting me confused who was on who's team, all the men look the same when you shooting them from far away.
popping people in the head is always fun :( but next time wouldnt mind a car race game chucked in there someone for good measure if anyone else is keen
still getting over the large supply of tissues there :P
all in all good ta see ya guys and meet a few new people.
o and yes pete is scary, he rides 1 of those bikie harley looking bikes.
Edited by gzilla
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
