Okay. The first Stagea cruise organised by Adam was a raving success. But we did hear alot of attendees talk about the need for a daytime cruise ... so here it is.
Meet at Castle Plaza car park on the Sunday 11th May at 10.00am. We roll at 10.30am on the dot.
Ensure you have fuel for the trip, or at least fuel to get to Victor (first stop).
Cruise will leave from Castle Plaza and work its way to Victor Harbor via Delamere.
Lunch/beer at Victor and then cruise up to Strathalbyn and back to Castle Plaza via Clarendon then South Road.
A map of the exact route will be handed out on the Sunday morning.
Any input and recommendations will be considered for the route/stops.
This is a Stagea only cruise. By this I mean we have all Stags up the front for the cruise. Tag alongs at the back. If we got other cars mixing it in, then it just becomes an everyday car cruise. Our last cruise really turned heads with the number of Stags driving down Jetty Road, and we want to turn more heads again!
So who's in? :D
https://www.sau.com.au/forums/topic/216839-adelaide-stagea-cruise/
wont be able to make it to this one i dont think coz i gota work lunch at the resturaunt for mothersday. not working dinna tho :)but as posted in the last adel stag cruise section every 2nd sunday of the month would be great! diff member or just follow the leader... trust me.. leading 12 stags... the rear vision mirror is INTENSE!
Howdy guys,
am reasonably new to forums and dont know many crew in adelaide w stagz.
Am from victor and have a pearl white S2.
Would be keen for a cruise but am chef also and is hard to organise time off.
Will keep eye on thread and do my best to make it!
Howdy guys,
Welcome delichef! :D
At this stage I'm going to organise the cruise for the Saturday 10 May 2008
Same time details as above.
Welcome delichef! :happy:
just got back from melb with my rs 4 s :D . seems to be goin well, is anyone still keen for this cruise :)
ok so, are we going for a cruise or not. just making sure cause im heading to victor saturday anyway and would prefer to make an enjoyable trip even better. looking forward to getting a look at all the stags in the daylight.
obviously! best idea would be to pm the dudes from my thread bout the 1st stag cruise. just keep bumping it etc
Chef, did you wanna take the reins on this one. I've had something come up.
I've PMed you about it.
ill go, i cant get enough of driving this car is sweet as bro.
lets get more people keen
actually i might not have my plates by then but well see.
Edited by pork hunt drifting
alrite.. ill be taking over this cruise. pretty much meet up well drive to victa one way. back another get lunch cheak out the stags, get sum pics n try and avoid any un wanted attention. any 1 got ne idea hook us up a pm. other than that ive got a route semi worked out. cheers guys
ill find out tomorow if my car will be legal to drive by then, im still on a permit from vic at moment. were u wana meet up if this goes ahead, castle p still. im at noarlunga what bout u guys
Chef, replied to your PM.
I'll map out the route for you and have it to you tomorrow.
:P
Maybe close this thread and start a new one with the Saturday 10 May in the title. The Mothers Day date may be putting some people off.
my stags not wanting to co-opperate with me today and its going to be off the road for a while as my trans has given in by the looks of things. might have to come out in another car at home but no too keen on that haha. is any one able to take the notes provided by ruby on the day and hand it out..?? cheers
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
