hey guys,
im not exactly sure what has been done to the car before i bought it, but i was told the HICAS had been removed, (lock bar or just completly gone, i have no idea)
but now this little problem has started where my steering is reasonably straight untill i hit approx 80km/h and then i have to turn my wheel atleast 20degrees clockwise to keep the car straight
during the 70-80km/h range theres a deep sound coming from the rear tyres
any ideas???
https://www.sau.com.au/forums/topic/217023-hicassteering-problem/
stick you head under the back of the car and have a look to see if you actually have a lock bar installed. it will be just behind the diff.
i have no idea what the lock bar would look like, im not really experienced with this stuff, all i know is what i explained.
if i do have a lock bar, would u know what the prob is, or vice versa??
Sorry to hijack your thread, but for those who know.. if your odometer doesn't work.. does it affect your hicas? I have the light come on and the steering gets really hard every now n then, its tempermental..
James: I removed via a lockbar.. if you remove the steering rack you need to put something in its' place to hold the tierods (things that adjust toe and/or are used for steering) or the back wheels would flop about a hell of a lot :/
You can get lock kits such as the tomei one which retain the steering rack but use an arrangement of washers to lock the tierods in place.
Karina: Yes it will affect HICAS and the speed sensitive steering. When the little needle on the end of my speedo cable snapped and I thus had no speedo, I had to drive around with heavy steering until I put a new cable in when I installed my new dash.
I now have a lockbar in the back, no HICAS solenoid thing in the engine bay, removed all the lines. Have also got a 25 box and a 280kmh speedo, I get the HICAS light on the dash after 1-2mins of driving but my speed sensitive steering is still there.. I believe if you unplug the HICAS ecu in the boot you will lose the speedo sensitive steering..
Edit: oops just realised you said "odometer", does this mean the speedo still works but the odo doesn't??
Edited by bubba
hey guys,
any ideas???
hey there,
my friend and i both had this same exact problem. his was while he had hicas and mine was after i removed hicas.
the cause is air in your power steering lines.
you may have a leak which is causing air to get in, but chances are slim since the system is high pressure and you would see oil everywhere or your hicas light would stay on in your cluster. give it a couple days of driving and using the steering wheel, and it should bleed itself out. otherwise, open the power steering cylinder cap in your engine bay and turn the wheels side to side for about 10 mins. if all else fails, flush the system and start over.
hope that helps,
dave.
I pushed the trip reset button one day and it just stopped working. Steering got heavy from then on and the hicas light starting coming on more often. Speedo works fine.
if you unplug the hicas harness, the steering will stay stiff. you have to snip the green wire with the white trace line on the bigger harness to disconnect hicas without damaging anything.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
