replacing the stock rims with a set of 18x8.5's What's the recommended size of tyre for this size/width of wheels? I'll do the research on the tyre brands myself as there'a a LOT of discussion in that big sticky thread above .. I just need to know the right size. Cheers
Also if someone could just quickly explain the tyre size lingo and what it means that'd be cool ie. 235/40/R17 (or some such)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/
anyone?? looks like I might be getting my new rims today so i'll need to go out and buy some rubber .. I've pretty much decided on Federal SS 595's but I'd like to know what size I'm looking at so as to be able to ring around and find the best price.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835253
Im running Federal SS 595's on my stock rims atm and they are a great tyre for the price.
Im running 235/45/17
Im no expert but here is my basic understanding
235 is the width
45 is the sidewall height in relation to the width
17 is obvisouly the rim size.
I've heard you can go as big as 275's on the back of r34's but you'd probably have to get your guards rolled. Im going 265/30/19's on the front and 235/35/19 on the back with my new mags and i'll be getting mine rolled to be safe.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835284
you mean you're going 235 at the front and 265 at the rear or are you really putting wider tyres at the front? Speaking of which, why is it so common to see people put wider tyres at the back when the rim width is the same ??
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835493
well my new rims are here all ready to go yay! Now I just need to decide on the tyres ... I see a lot of good responses on the Federal 595SS so I might as well go with the flow. Now just to find the right size
The stock rims are only 17x7.5 but the tyres on them are 225/45/17 - thats like 8.85" wide tyre..doesn't that seem a bit wide for a 7.5" rim?
Edited by Delta Force
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835583
what about 235/40/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1cm larger diameter at the FRONTS and 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Edited: fronts were meant to be 235/40 not 45
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836171
what about 235/45/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1.3cm larger diameter at the rears 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Why do you want to put a smaller tyre on the front, do you want it to understeer?
Over 60% of the weight is on the front tyres.
Cheers
Gary
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836190
Cheers
Gary
Sorry I've fixed that typo. it's the fronts that would have a 1cm larger diameter with that sort of setup ... is that any better or still stupid? Should I just go 235/40 front and rear?
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836201
K I've decided to try the Maxxis Z1's due to price being only $179 per corner and me not being able to find ONE negative review for them plus they seem to have won some Wheel's price/performance test.
Now just to get the size right !!
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836342
Yeah my bad, was typing up a quick response while i was 'working' and didn't check it before posting
Bigger tyres on the back is an effort for more traction i'd say, yeah it might/probably will understeer but who really races their skylines on a street setup?...well their daily driven skylines anyway.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836431
I'll speak to the BJ guy tommorow and see what he reckons... I'd "like" 235/40/18 at the front and 255/35/18 ar the rear - but that means the fronts will be 1cm bigger (ie. sidewall 0.5cm higher). I'm not sure if that's a bad thing - I'll see what he reckons and go from there. Thanks all.
Edit: or maybe instead of the above setup, I'll go 245/40/18 all around. That'll give me a higher side wall (better ride comfort??), it's only 1.9cm extra diameter and 3% slower than speedo says (driving 97kmh when it says 100kmh)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836446
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
