Hey Guys,
I have bought myself a power FC, hopefully getting here this afternoon or tomorrow.
It is my understanding that the base map on it will be safe to run the car with for awhile before getting a tune yes? I have stock injectors and AFM, stock turbo running around 11psi.
I can just replace the stock ecu and drive the car like normal? How safe is the stock PFC map? And in theory could I drive the car every day for say a month or two without having to worry about getting a tune, or should I wait until I can get a tune done at the same time?
On an unrelated note, when booting it in my car, usually in 2nd and 3rd gear, full throttle results in lots of popping and sluggish acceleration, but say 80% throttle it pulls hard. I am thinking either lower gapped plugs might fix this or perhaps my coils are stuffed. Thoughts?
https://www.sau.com.au/forums/topic/217197-quick-powerfc-question/
no problem driving the car for a while on the base tune. personally I wouldn't be taking it to the circuit or drag strip in that time but just driving around will cause no problems. ;)
The basic PFC questions are covered in the PowerFC FAQ
Have you read it?
I have yes, it is very usefull and I will be using it as a reference while doing the swap. It does breifly mention that the base map provides more torque etc etc but also reccomends a tune (obviously)
I just want to make sure that until I get said tune, I am not risking my engine by driving to work for a few weeks.
the problem with your car accelerating sounds like a coil issue had the same problem with mine only when i stamped on the gas the car would miss one hell of a lot check all my coils to find 3 had been replaced with new items and the others were still original pulled them out and found cracks in them replaced them and haven't had any problems at all used to be kinda scary when over taking and you plant the foot and the car just doesn't seem to pick up fast enough and you've got traffic heading your way
Haha yep, I have to make SURE i have plenty of space when overtaking to allow for a few periods of poor acceleration. I have suspected my coils for some time but never actually inspected them, I might pull them this arvo and do a visual inspection, see if there are obvious signs. I would happily buy some splitfires but they aren't exactly cheap.
Ok I got the Power FC this afternoon and was determined to get it all working myself.
Put it in, attached Loom. Car dies within 1 second of starting. Yes I cleared the previous data and also set the boost control option to off. It seems to be saving data fine, the car just won't start properly. Starts, gets to maybe 800rpm then dies. Giving it some throttle makes no difference.
Any help is much welcome
EDIT: Ok is running now, I had a Safc before which I had disconnected, plugged it back in but set it to not do anything, PFC is now idiling the car. Must be some wiring issue.
Edited by Lachlan33
spent 5 bucks on a tube of ultra blue(gasket silicone maker) covered my coils to insulate them, never had a problem again, even when running 16-17 psi, its tight arse and doesn't look good but beats spending $100s of dollars on splitfires...
Hope this helps.
Ok just got back from a quick drive with the PFC. And holy crap, even without a tune I love it already.
1: Car no longer pops and bangs every gear change or throttle lift (not that I really minded that :domokun:)
2: With an Atmo BOV I used to watch the revs dip very low and have to catch it or risk stalling (made stopping at lights a PITA). Using the PFC I set the idle to 800rpm and this problem now does not exist. It hunts a little but never dips below the 800.
3: I have my full throttle back! Its been quite awhile since I have gone WOT in the car because it would just start to miss, pop and bang and my acceleration would go out the window. This is now 95% fixed, the car pulls hard again. I heard the odd pop here and there a couple times but its chalk and cheese to what it was before
4: The car overall feels more like a proper working car again and not some backyard tuner deluex with dozens of minior issues I had gotten used to.
PFC FTW!
Edited by Lachlan33
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
