Hi,
Ive recently finnished my 'rb26 into r32gtst' project, but im having troubles with an exhaust that is too loud. The car has got about 350rwkw on low boost setting, and ive currently got a Trust TR Drag 3.5 inch exhaust on it. This exhaust consists of a 3.5 inch metal cat, a hot dog, and then a cannon type muffler with perforated tube straight through it. Its over 100db at 5000rpm and thats WITH the silencer in it. It also drones like a bitch in the cabin.
Ive spoken to a few people in the know, and they ALL say that i wont get an 'off the shelf' exhaust that wont restrict the cars power. I dont want to spend 20 grand getting 350kw and then restrict it with an exhaust, so it seems ive got to go the custom route.
Apparently the best way to go is an oval centre muffler that is glass fibre packed, and uses (3.5 inch) perforated tubing that enters the muffler, then makes a 'U' shape before exiting the muffler. Im not sure about the rear muffler though. I imagine it would use perforated tubing with glass fibre but without the bend in it.
Anyway, my problem is that i can only fit a centre muffler that is 12 inches in length under the car while still maintaining suitable ground clearance. There is no way that a 3.5 inch (or 3 inch for that matter) pipe can make a mandrel bend to sufficiently muffle sound in 12 inches.
Surely there are people out there who have tackled this problem before. Im after a free flowing exhaust that is legal (or as close to), and doesnt attract attention. If anyone with experience in creating such an exhaust can help me (or knows someone who can), it would be much appreciated. Ive found a few people in the Melbourne area, but i think it would be difficult to make a custom exhaust, as i am near Sydney.
Thanks heaps, and sorry for the long post.
Shaun.
  • Replies 43
Posted Images
I almost bought a TR as well. If you want to keep that rear cannon (which would be doing very little sound muffling) then yah, you'll need a custom oval muffler where the resonator is now.
Iv seen good results from Hi-tech and SMB in Sydney (both can offer advice and make one off mufflers on site.
Nizmoid has recently had a system made for a RB of similar power. He ditched the cannon and used an oval muffler at the rear though.
I use side in center out magnaflow rear silencers (straight threw pref tube) at the rear and get a regular 304 twin 3" stainless tip and convert it to run 3.5"... Makes the system nice and quiet, doesnt restrict power and doesnt draw the cops (serious problem here in South Africa)
With a side in center out you can get away with using 1.5 90' bends for the full system, above was a 3" system I did for a S13 to shut it up with a 330wkw SR20, its a bad example because its got a lot bends but it gives you the idea
Edited by Rezlo
My Gt-r was running a T88 when it came from japan...
It had a 3 and 3/4 HKS Priest Exhaust system, No cat and it was around 100db, it has a oval rear muffler which made it very easy on the ears!...But i changed it up for the Trust TR system although mine was 4'' on special order...
So i reckon if you could use that type of muffler with the rest of your exhaust system that should work?
Hey, thanks heaps for all your replys.
Im not fussed about keeping the rear cannon. In fact, id rather go for an oval or more standard looking rear muffler as many of you have suggested.
GeeTR, im having a bit of trouble finding both Hi-Tech and SMB in Sydney. Do you know what suburb they are in?
I was expecting to have both a centre oval and rear muffler made up, but from what some of you have said, maybe i can get away with just the rear muffler being replaced??
Anymore hints as to which work shops can do this for me without experimenting. I need tried and proven methods, as coin is a bit of an issue!! Ill keep trying the above workshops in Sydney.
Thanks,
Shaun.
You can have two mufflers, both straight through, and still be 90-92dB.
Mine is 3.5" all the way.
Check my gallery for some pics - all custom of course
Hey, how do i get to those pics? The gallery just shows Thailand pics.
Any idea on the construction (internally) of your mufflers?
Thanks,
Shaun.
I have two Albums - just click the other
http://www.skylinesaustralia.com/forums/ga...-album1130.html
Thats a direct link, there are about 5-6 pics to give you an idea.
Also remember its a HR31, so muffler size/position is different but it'll give you an idea of where to start and the fact you need some pretty hefty mufflers. All mufflers were custom made for my car, so i cant offer much for the construction there :P
Any exhaust shop experienced in big power should be able to work magic though
Hi Tech
344 Bourke Street, (cnr Short St)
Darlinghurst NSW 2010
Sydney, AUSTRALIA
http://www.hitechmufflers.com.au/home.php
SMB
11 Aero Road
Ingelburn,
NSW 2565
http://www.smb.net.au/
Thanks mate,
I couldnt get onto SMB, but rang Hi-Tech today and they said they could help me out.
Ill keep researching..............
very easy option would be to get a butterfly valve installed..... when putting around town, your effective exhaust size is about 2".. pull a lever, open up the valve and your straight back to 3.5" when you want to fang it (on the track of course).
keep in mind, this is not a strictly legal option....
I first r32 came with a jap cat-back that just had a rear oval canon and was so loud I couldn't drive at the same speed for longer than a minute on the motorway without ruining my ears due to the drone. Dropped my car into 'Penrith City Exhausts' and got Eddie to make a new custom cat-back with a centre and rear magnaflow oval mufflers.
Not only was the drone completely gone, but it was no longer illegal and he managed to mount it about 2 inches higher so it wouldn't scrape like the jap exhaust did. All up it cost me $1000 drive away and was very good quality.
^^ Yeah but 3" isnt going to handle 350rwkw.
You need something special to make power and be quiet @ those kinda flow levels.
^^^^^^Yeah this is my problem. Its easy to make it quiet, but i dont want to kill my power in the process.
There seems to be plenty of options, however, so ive just gotta find someone with experience in this area to make me a custom exhaust.
Thanks for your replys, ill keep you posted.
Paul, ill give you a ring and get the Thornton shops number.
Shaun.
I was talking to X Force about their rear muffler that has a butterfly integrated in the design, and its electronically controlled. When closed, it directs gasses through baffling in the muffler (quiet), and when open, its a straight through design. Their 3.5 inch oval muffler is being developed now and should be ready in 2 - 3 months.
Idealy, id like an exhaust that flows the power and is quiet (the holy grail), but alternatively this option might be ok.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
