Nick just suggested seeing what it would cost for one brand new. There is no way i'd go new for that price.
Have you been able to get a hold of a Z32 AFM yet for your build?
...talking about builds, at the workshop where I take my car there was a R33 gtst with high mount CGC turbo (600hp X?? range). started spooling at 4000rpm and hit full boost at 5500rpm.
He had what looked like a modified standard plenum that was forward facing, turbosmart external wastegate, and worked internals.
Where you going that extreme (basicly it was for drag racing and not that much for street).
Mark
Guest INASNT
i had the z32 afm ages ago, i just got the plug for it yesterday and its all installed. I got external gate and 3037 going on custom manifold! the internals are staying standard till it blows or when i decide to spend more dosh at once with headwork, 1.6mm head gasket, forged piston, short penned rods and nitrided crank!
Mark
That would be this one ?? Same as the one I want for my RB30DET Conversion...
Im not sure what brand it is, my mechanic had it and put it on the exhaust side. It wasn't touched when I got the tune as the guy tuning didn't believe it made any difference.
I heard cams can make a difference of 30kw in the lower power band, is that correct? might be worth investing in some.
Mark
Hi Mark25T,
You can buy Z32 AFM's from Petroject in sydney, in an as new condition go to http://www.petroject.com.au/ and look under EFI parts or call them on 1300 30 40 60, they won't cost you $850 thats for sure!
As for the plug that connects to the Z32 AFM yes you will need to get a new one. The plug that goes onto your existing AFM will not plug into the Z32AFM however all you need do is obtain a plug from a RB30 (out of a VL) as this plugs straight onto a Z32AFM..well it did when i installed Z32AFM's on my car! Just take your Z32AFM to any VL wrecker to make sure it plugs straight on.
cam gears make a huge difference in the tuneability of the car. My car was not making boost until around 4200rpm and full boost not being reached until after 5000rpm I then had it tuned with heaps of attention being paid to the cam timing via the cam gears...end result boost starts at 3000rpm and reaches peak boost at 4400rpm, thus much better street performance. Really just depends on what you want your car to do!
Cheers
Guest INASNT
Originally posted by STUGTR
Hi Mark25T,
Cheers
retard the exhaust cam gear by 4 degree and u get a good power gain
Guest INASNT
Petroject doesn't sell them anymore because they have had problems in the past. They recommended Hills because they are not dealing in them anymore.
Any other suggestions Stu?
Mark
search the for sale section u will find 1 for sale, i bought mine from the forums
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
