ok guys my knowledge of japanese language is very limited.
i do remember some basic stuff from learning it back at high school but not much.
i want some words and small sentences converted into japanese.
like if i say "my name is james"
if i remember correctly that is spoken as "boku wa james desu"
but i also want what im saying converted into the symbol form.
i know theres a few like hiragana and katakana ect.
let me know if u can help and i will pm u with the few words/ small sentences that i want translated into 'spoken japanese' and into 'symbol form'
lol hope this makes sense.. please help
Edited by tm_r33
https://www.sau.com.au/forums/topic/217680-english-to-japanese-translation/
Formal version: "watashi wa James desu" ?
I think "Boku" is the informal way to say it.
Google is you friend,for basic translations and small sentences use that.I did a 4 week crash coarse before i went to Japan.It helped alot,though i wish i learnt more.
First one i found,but there are plenty more that go more indepth.
http://www.japaneselifestyle.com.au/japane...hrase_basic.htm
