1988 S3 TI For sale. 235,000km on the body, and 44,000km on the engine
Modifications:
RB25DET NEO Engine from an R34
T04 turbo installed
NISMO 550cc injectors
Bosch 040 in-tank fuel pump
3" Exhaust
Sillohuette LSD modified and strengthened LSD diff
EMS Stinger 4424 computer
front mount intercooler
battery professionally relocated to boot
this car is the neatest R31 I have seen (since they were new!)
The paint is like brand-new. my estimation is it has been professionally resprayed within the last 5 years.
the interior is immaculate also. it has been professionally restored, the dash is perfect, it has brand new carpet, seats in perfect condition.
it is a normal looking, stock dark green skyline.
The sound system is great. It has an Eclipse head unit in it (not sure on the model, but it cost $700 new around a year ago), and has a 12" sub and amp in the boot.
What it will need doing to be a dream car:
It still has the standard R31 Auto in it. Not a big problem at all, could put a R32 5 speed in for around $500.
It has a hole in the muffler
It needs a dyno once the 5 speed has been put in. (runs a little rough)
In saying the above comments, I must mention that it is still very very drivable, extremely reliable, and has monster power.
With these modifications made, it would easy pull a 12 second quarter mile.
It's not registered with the RB25 in it, but from what I believe it would be easy to change the engine number over, and at the worst require some R32 brakes.
It does come with 11 months Rego, but no RWC. (am happy to leave the number plates and rego intact for the right buyer)
was going to finish this car off as a project, but lost interest and too busy.
PICTURES UP AT: www.jasontresize.net/r31ti
asking $6000 ono, located in BENDIGO, VIC
Phone 0403 916 715
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
