Hey Guys,
Ok so starting a cleaning business in Newcastle - will be specialising in Commercial and Contract Cleaning. Having a complete mind blank as far as names are concerned. Have my graphic designer ready to go with logos etc.
Lend a hand! Need some suggestions of names - motto's etc
Will most likely be something in it if a name is chosen.
Get creative, very open to hear anything!
HALP!
Regards,
Chris
https://www.sau.com.au/forums/topic/217871-creativity-inside/
lean mean cleaning machine: no job to big for our lean mean cleaning machine to be seen by team beam hydro steam... yo
crystal clear cleaning
dust musterers
green clean (people will think your methods are environmentally safe and hire you even if they are not) just like the green energy gimick :whistling:
better than mr sheen cleaning co.
mr sparkal (simpsons)
The Happy Scrubber!
Happy Scrubbers!
Man Maid
Chore Whore cleaning services..
Or you could put em all together
Man Maid Happy Scrubbing Chore whore..cleaning services !!!!!
One shiny dollar per letter if you choose any of the above :dry:
The Happy Scrubber!
Happy Scrubbers!
Man Maid
One shiny dollar per letter if you choose any of the above :merli:
haha if I end up with that I'll give you $1000
I'm just that nice of a person
:dry:
:dry:
Ok ok ok ok ok ......ok
Try this:
A Man, His Mop, their Dream.... MOPMAN a love story
Best said in an Hispanic accent or Movie voice over style!
(also good as a dipping sauce for chups and widgis)
Edited by madbung
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
