do any of you guys with the NA r33's...just like mine have ;loud exhausts but none of dat mechanical whirr?
whenever a skyline goes by, there's this mechanical whirr...whirrrrrr kinda sound but mine just has a boooooommmm kinda sound...doesnt sound like the gtst at all...
ne of ya'll got this problem?
thanks guys...n just wondering..=)
https://www.sau.com.au/forums/topic/21831-no-mechanical-whirrexhaust/
im not exactly sure if this is what ur talking about but that mechanical noise i assume ur describing is the turbo spooling up. There are very few of us NA boys out there so id say everytime u see/hear a skyline it is most of the time a turbo.
I not sure what you are talking about but...
here is a video clip of my R33 GTS-4 revving up at the light.
its Gun metal Grey with SDU (skylineDownUnder) sticker at the back... its abotu half way of the clip after R31 sleeper :(
I loved the sound of my sky.. pretty loud compared to Turbo cars cuz you know why... :D
enjoy guys and put some your clip if you have them.
NA R33 GTS-4 vidclip approx 3.3MB
cheers
Joey
i think there are some sort of pod filters available with a plastic cover over them that whistle as air is sucked through them if u want that kinda sound, though they look fairly restrictive to me, not sure what brand either.
heres a few ideas ive heard, to get a nice exhaust note drill a hole through ur exhaust pipe before the muffler, get a bit of guutar string and tack weld it thourgh the pipe, voila u have a wonderful note! another one was to stick a PC fan before the muffler and ull get a turbo whistle lol, never tried it doubt i will! i was gonna try putting a whistle (from those vortex things) in the pod filter before the AFM, lame ;)
I think what streamer was referring to is the difference between the noise of an NA exhaust and the noise of the turbo exhaust...
The NA has a mechanical "zing" sound to it, which I don't ever want to give up even if my exhaust is inefficient.
The turbo has a much lower quieter sound due to the greater flow/less restriction.
correction... its due to its length of the exhaust...:P
Longer pipe = Lower pitch (Bass)
short pipe = hight pitch
add- Longer pipe >(greater) restriction
cheers
Joe
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
