do any of you guys with the NA r33's...just like mine have ;loud exhausts but none of dat mechanical whirr?
whenever a skyline goes by, there's this mechanical whirr...whirrrrrr kinda sound but mine just has a boooooommmm kinda sound...doesnt sound like the gtst at all...
ne of ya'll got this problem?
thanks guys...n just wondering..=)
https://www.sau.com.au/forums/topic/21831-no-mechanical-whirrexhaust/
im not exactly sure if this is what ur talking about but that mechanical noise i assume ur describing is the turbo spooling up. There are very few of us NA boys out there so id say everytime u see/hear a skyline it is most of the time a turbo.
I not sure what you are talking about but...
here is a video clip of my R33 GTS-4 revving up at the light.
its Gun metal Grey with SDU (skylineDownUnder) sticker at the back... its abotu half way of the clip after R31 sleeper :(
I loved the sound of my sky.. pretty loud compared to Turbo cars cuz you know why... :D
enjoy guys and put some your clip if you have them.
NA R33 GTS-4 vidclip approx 3.3MB
cheers
Joey
i think there are some sort of pod filters available with a plastic cover over them that whistle as air is sucked through them if u want that kinda sound, though they look fairly restrictive to me, not sure what brand either.
heres a few ideas ive heard, to get a nice exhaust note drill a hole through ur exhaust pipe before the muffler, get a bit of guutar string and tack weld it thourgh the pipe, voila u have a wonderful note! another one was to stick a PC fan before the muffler and ull get a turbo whistle lol, never tried it doubt i will! i was gonna try putting a whistle (from those vortex things) in the pod filter before the AFM, lame ;)
I think what streamer was referring to is the difference between the noise of an NA exhaust and the noise of the turbo exhaust...
The NA has a mechanical "zing" sound to it, which I don't ever want to give up even if my exhaust is inefficient.
The turbo has a much lower quieter sound due to the greater flow/less restriction.
correction... its due to its length of the exhaust...:P
Longer pipe = Lower pitch (Bass)
short pipe = hight pitch
add- Longer pipe >(greater) restriction
cheers
Joe
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
